35mm and 18mm hood caps
Discussion in 'Fuji X-Mount Lens Forum' started by Ario Arioldi, Mar 24, 2012.
  1. Ario Arioldi
    Ario Arioldi Member
    Mar 21, 2012
    143
    I do not know if it is only a problem of my own samples but the hood caps of both the 18mm and the 35mm are very loose and hardly stay in place. I have put some tape on the hoods to improve the grip but this seems not to be the proper solution.
    Any idea?
    Ario
  2. fearofhummingbird
    fearofhummingbird Member
    Oct 1, 2011
    201
    I haven't received my camera yet. But I read on a forum somewhere that they have to be popped on - like tupperware. Then they are really secure.
  3. JSolomon
    JSolomon Member
    Feb 7, 2012
    128
    Lyon, France/Taipei, Taiwan
    Tupperware is something I remember from my childhood in the United States, but I have no idea what it is like today, so I cannot comment on the analogy. "Lock and Lock" it is not.
    The hood cap on my 35 falls off quite easily, too. It is quite easy to "pop on"--there is no trick involved here--and it will not off simply because of gravity, yet gives up the goose at the slightest provocation. Just touching the edge of my Domke coming in or out of the bag is enough to bring it off.
  4. Ario Arioldi
    Ario Arioldi Member
    Mar 21, 2012
    143
    I wish the were like the "tapperware", believe me they are not, at least my own two samples.
    Ario
  5. cdodkin
    cdodkin Premium Member
    Mar 2, 2012
    633
    187
    California
    I do find that you can put the caps on and have them fall off - or push them on, and they will stay put unless knocked.
    Still poor design though
    Could be a mute issue as I've ordered new lens hoods for the 18mm and 35mm, as the existing hoods are useless when you need to adjust a filter such as a CPL or grad - there's simply no access! :(
    Went with a vented metal hood
  6. HandcarryOnly
    HandcarryOnly Member
    Mar 19, 2012
    37
    I've given up using either the pinch caps or the hood caps, so the lenses are in my camera bag with hood, but sans caps now. Let's me get into 'shooting mode' faster anyway :)
  7. MiZe
    MiZe New Member
    Aug 28, 2011
    38
    My 35 mm has the same issue. Seems to be the design. Do you have the 60 mm as well? No problems there?
  8. MiZe
    MiZe New Member
    Aug 28, 2011
    38
    And this looks so much better than the original :) I really miss the look of the X100 hood!
    Ebay? Do they come with some form of cap included, or would you know what third party caps would fit this hood?
    The 35 mm seems prone to flare. Could you please report how well this hood reduces that?
  9. cdodkin
    Mar 2, 2012
    633
    187
    California
    Sourced them from EBAY EBAY
    No cap included - I'm guessing they will take a standard 52mm pinch cap - will confirm when they arrive.
    Will take test shots to report back on flare when I get them as well
    Chris.
  10. Ario Arioldi
    Ario Arioldi Member
    Mar 21, 2012
    143
    The 60 mm hood does not have any cap. Due to the cylindrical shape you can use the regular lens cap, which is fine.
  11. juusom
    juusom New Member
    Mar 6, 2012
    Hmm, that hood looks very nice and it's cheap too. Only problem is now that seller is only shipping to US, I would need shipping to Europe. Have anyone seen these elsewhere?
  12. MiZe
    MiZe New Member
    Aug 28, 2011
    38
    Seen and ordered :)
    http://global.ebay.com/52mm-Metal-Lens-Hood-Cap-for-Fujifilm-X-Pro1/400281226667/item
    A few EUR more but a cap is included.
  13. flysurfer
    flysurfer Premium Member
    Aug 14, 2011
    3,239
    687
    NUE
    It never occurred to me that one would or could use those hood caps when carrying the camera in the open. I was always under the impression that they were designed to protect the lens when carrying the lenses in the bag with the hood still attached. So I never ever put those caps on with the lens attached to the camera. I had to chuckle when I realized that folks were actually trying to run around with those sloppy things, for sure losing/dropping them all the time. ;) I really don't think this is a good idea.
    There is a plastic lens protector included for each of the three lenses that won't fall off easily, I think this is the one you are supposed use on the road for lens protection, but you'll have to remove the hood in order to reach it. Remember, there never was a cap for the official X100 (or X10) lens hoods, the hood itself is supposed to be protection enough.
  14. juusom
    juusom New Member
    Mar 6, 2012
    Wow, that was fast ;) Thank you very much.
  15. aleksanderpolo
    aleksanderpolo New Member
    Mar 6, 2012
    50
    How about one of these:
    http://www.ebay.com/itm/230754551374
    I use them on my CV 15's metal cap, which always feels loose and I am afraid I will lose the cap one day somewhere. Not sure if they will stick on a rubber cap though.
  16. cdodkin
    Mar 2, 2012
    633
    187
    California
    Lens hoods from EBAY arrived today - result! They look excellent and fit nicely
    No vignetting on the 18mm - viewfinder view is not obscured as you can look through the slotted hood (as you'd hope)
    The original pinch type lens caps now fit the hoods perfectly.
    Will take photos tomorrow for ref
  17. MattPowell
    MattPowell Member
    Oct 12, 2011
    119
    That was kind of what I assumed - I don't see a need for a lens cap with hoods like those on the native X lenses.
    I didn't even use a cap with the hood on my X100, but I was careful to not have anything else in its compartment in my bag.
  18. Ario Arioldi
    Ario Arioldi Member
    Mar 21, 2012
    143
    Everybody is free ti choose if and when to use the hood caps, but the hood caps have to be designed and built to stay in place, there is no excuse.
    Ario
  19. flysurfer
    Aug 14, 2011
    3,239
    687
    NUE
    Well, but they aren't, so just imagine that those caps don't exist at all and weren't part of the lens package. You know, just like it is with the X100, which also doesn't offer a cap for the (pretty expensive) lens hood.
    I guess if Fuji had simply left out these caps, everybody would be happy? In any case, I don't remember rants about missing lens hoods caps for the X100... ;)
    Personally, I take the rubber thingie as a nice addition to protect my lens while it is in the bag. That's what it is actually useful for IMHO, but nothing else.
  20. matty_westside
    matty_westside Premium Member
    Jun 12, 2011
    1,630
    836
    is the '52mm' on the hood a sticker or engraved into it?
