AF-C Custom settings
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by Camiel, Mar 20, 2017 at 8:42 PM.
  1. Camiel
    Camiel New Member
    Monday
    Hi, I'm new to Fuji and new to this forum. I have a question about the af-c custom settings on my new X-T2 camera. How do these work/interact in combination with the "single point", "zone" and "wide/tracking" settings? For example, suppose I would like to use custom setting 5. Do I have to, e.g., select "zone" or "wide/tracking" so that the custom setting 5 actually works?
  2. nwcs
    nwcs Former Gear Addict
    Aug 6, 2013
    1,819
    495
    Tennessee
  3. Camiel
    Camiel New Member
    Monday
  4. nwcs
    Aug 6, 2013
    1,819
    495
    Tennessee
    Your custom settings would be applied in all the modes: single, wide, and zone. So the settings are about bias applied to the current AF area mode.
    Personally I found #5 not to have any advantages.
  5. Jonimages
    Jonimages Premium Member
    Nov 19, 2014
    401
    238
    Silverhill-AL
    Your question is open ended and it's a depends answer. I highly suggest playing around with the settings to see what works for you. There are times I have zone set, others it's single point. The setting depends on the subject and what's going on. If I'm shooting sports, I may have a wide zone. If I'm shooting hummingbirds around flowers it may be wide focus or single point. Spend some time with the camera and lens combination and find what works.
  6. Dirk Offringa
    455
    200
    I had found this document somewhere, I don't know if it was on this forum or elsewhere, it was drafted by someone who goes by the name of Wim Arys I believe. I edited it a bit (for my own reference) because the original layout was a bit confusing, but I'm not the author. It was written 2 years ago for the then-current Fuji line-up. I found it useful when I started with the Fuji system. Hope this helps.
    Camiel and stanbax like this.
  7. Dan Bailey
    Dan Bailey Well-Known Member
    Mar 6, 2014
    229
    241
    Anchorage, Alaska
    Hi @Camiel, welcome to the forum. I recently wrote a detailed article about how the AF-C custom settings work. I hope this helps you understand the system a little better.
    Here's the link. Let me know if you have any questions.
    Camiel likes this.
  8. stanbax
    stanbax New Member
    Mar 13, 2017
    Excellent tip !
  9. Camiel
    Camiel New Member
    Monday
    OK, great, thanks for this answer! I wanted to shoot a soccer game and wasn't sure how exactly the AF-C custom settings work. Which mode (single, wide, zone) would you generally recommend to combine with a AF-C custom setting for a soccer match with 9 year olds?
  10. Camiel
    Camiel New Member
    Monday
    Thanks, Dirk! Just printed the doc and will read it thoroughly!
  11. Camiel
    Camiel New Member
    Monday
    Hi, Dan! Just wanted to let you know that I really appreciate you sending me the link. I also downloaded your mini-guide. This helps a lot. Many thanks!!
  12. nwcs
    Aug 6, 2013
    1,819
    495
    Tennessee
    I think of young children like wildlife, lol. At least mine acts like that! So I use zone mode exclusively and with a setting of tracking but ignore obstacles.
