Afl Button Focus Method
Discussion in 'X-Pro2 and X-Pro1' started by RichC, Dec 4, 2012.
  1. RichC
    RichC Member
    Mar 24, 2012
    104
    17
    Hi all.
    I haven't used my 60mm much lately, in fact I don't think I have used it since the last firmware update!
    So, I thought I would take it out and give it a good thrashing last Sunday as the weather and light was pretty good. I have always used AF by half pressing the shutter button, finding the process to be quite adequate with a good/acceptable success rate.
    This didn't seem to be the case on Sunday. I always shoot several pictures of the same scene to make sure I get at least one useable picture. Previously, ie. pre firmware update, pretty well all of the shots would be keepers. I was somewhat disappointed to find that in some cases I was struggling to find 1 shot from a sequence that I could use.
    With the 60mm I always use the EVF.
    I have done a bit of fiddling around and "I think", I might be getting a slightly quicker, and more reliable focus lock by using the camera set to MF and focussing with the AFL button.
    Am I kidding myself here, or is anyone else finding the same?
    I intend to go out tomorrow and shoot a whole load more using the AFL button method to see what happens.
    Rich.
    Topsy likes this.
  2. RichC
    RichC Member
    Mar 24, 2012
    104
    17
    mmmmm.........thought that might have resulted in some thoughts from the experts.
    It's ok, I have answered my own question. I took the 60mm out again today and used the AFL button for all shots. Focus lock was quicker and virtually all shots were in focus.
    Happy days! :rolleyes:
  3. Topsy
    Topsy Premium Member
    Dec 2, 2012
    1,738
    680
    Devon, UK
    Hi RichC, I have just tried your suggested method and I think you are right, I hit focus more successfully in poor light or close up than in normal AF. Thanks for the tip.
  4. Al Downie
    Al Downie Member
    Oct 30, 2012
    47
    Cambridge UK
    I'm seeing exactly the same results every time - shoot one frame with autofocus, and one frame with manual/AFL, and the manual/AFL shot is noticeably sharper. This is great - I've been struggling with poor autofocus for the last few days, thinking that either I must have been expecting too much from my X-Pro1 & 35mm, or that there must be something wrong with my technique despite a month's worth of experience with the X100 and an awareness of the foibles of the X-system focussing. Finally I can clearly see that the system is capable of producing good results, but just not by the normal autofocus method.
    Thank you VERY much for this tip!
    Al
  5. RichC
    RichC Member
    Mar 24, 2012
    104
    17
    Thanks Guys. Glad I'm not the only one to find this.
    I am certain I had read this, or something like it in another thread some time ago, but I couldn't find it, it might have been on another forum.
    It seems strange to me as I was getting really good, and I mean, really good results by using the shutter release button to focus pre fw 2.01(?)
    The 35mm still seems to give good results using the old method though. That said I think I will now just use the AFL button with all lenses.
    Thanks again for your replies.
    All the best.
    Rich
  6. RichC
    RichC Member
    Mar 24, 2012
    104
    17
    Al
    I've come to realise that there is nothing normal about Fuji :D
  7. Sapphie
    Sapphie Premium Member
    May 19, 2011
    276
    Devon, UK
    The 2.01 FW update says it improves AF accuracy using the AFL button. Are you guys saying that they have effectively made 'normal' AF process worse, perhaps by introducing some newly introduced bug?
    Lee
  8. Al Downie
    Al Downie Member
    Oct 30, 2012
    47
    Cambridge UK
    I can't answer that question I'm afraid, because v2.01 is all I've known. But it certainly seems to me that the 'normal' autofocus method is much less reliable than the manual/AF-L method, on my camera.
  9. RichC
    RichC Member
    Mar 24, 2012
    104
    17
    Hi Lee.
    I can't really say for sure. My 35mm seems ok with the "normal" focus method, but the 60mm is definitely not the same. It was fine before fw 2.01.
    Rich.
  10. EyeForget
    EyeForget Premium Member
    Apr 10, 2012
    2,234
    478
    USA & Switzerland
    This is day 3 of an xe1 with 35/1.4 on 2.01. Although I'm still new with the camera, I've had an X100 for a year. Yesterday I was not impressed with the focus accuracy I was getting. So went at it again today.
    I just took 20 shots of an octopus in the kitchen (not close) and all the shutter button would do is hunt forever, never reach focus and flash up red boxes. An octopus, with its gelatinous skin may be difficult but I could not achieve focus on anything within 3 feet of the lens. Going to M and pressing the AF button worked every time, and quickly.
    Also shot some shots in the garden at about 4 feet. No question I'm getting better and faster focus in M.
    Am I correct that the minimum focusing distance with the 35 is 28cm?
    Here's an update. I had the focus square set to the smallest square. Putting it back to the default square helps (that's one size up from minimum and the same size that's displayed in manual focus mode) somewhat but it still pales compared to using manual focus mode. In a nutshell, I can lock focus after about 5 attempts in S. I can lock focus just about every time in M. M achieves more accurate focus.
    I just pulled out the X100. A cakewalk in S. Same shots (other than the octopus which is now in the pot), no problem at all achieving accurate focus and quicker than the xe1/35. Viewing off the lcd suggests I'm also getting better focus accuracy with the X100.
  11. jzzmusician
    jzzmusician Member
    Dec 27, 2011
    82
    I like using manual focus and the AF button as well but the lack of corrected focus boxes in manual mode puts me off when shooting close. It works when using the electonic viewfinder but not OVF.
  12. jknights
    11,434
    2,135
    I prefer to use EVF with the 60mm and make sure that I can see everything I want in sharp focus.
    With the 35 and 18mm lenses there are different issues.
    I find the 18mm doesnt focus accurately where the focus point is on screen but that is easy to get round by shooting at f8-11 everything is in focus.
    The 35mm behaves perfectly!
    I will be very interested to see how life changes with the 18-55mm zoom.
  13. GTech
    GTech Active Member
    Aug 23, 2012
    182
    34
    United Kingdom
    I must admit that using the AFL button (back button focus) method this weekend did improve the hit rate on both the 35 and 60mm, moreso when using the EVF. It's funny, I've used the back button focus method for years on Canon dSLRs, so its quite natural.
    The only downside is the lack of visual confirmation (illuminated green box) and the need to rely upon an audible beep (I hate beeps)....now there's a another firmware update to consider.
  14. denis.lincoln
    denis.lincoln Apartment Smells of Rich Mahogany
    Jun 7, 2012
    1,130
    1,108
    The Mission, San Francisco, CA
    I've slowly been training myself to focus using this method and fine focusing with the focus ring if necessary. As I spend a lot of my time with legacy lenses on my X Pro 1, I will have to reserve judgement as far as keepers with the 35, but the initial 'feel' of the exercise is that the camera is snappier and more accurate when doing things this way.
  15. gambofoto
    gambofoto Member
    Sep 10, 2012
    145
    23
    A friend and myself have both been using the AF-L even before the last several updates with better success then with the cmaera in AF-S mode. It also seems to me that my 35mm hunts more now in AF-S then it did before firmware 2.0.
    Sorry I did not respond earlier, been off for a few days.
  16. MuMinded
    MuMinded Premium Member
    Jun 20, 2012
    545
    372
    Japan
    I had been using this method of AF since I was first using my old Fujifilm S2 DSLR.. To be honest, I can't remember why I got in this habit but it is now just naturally a part of my shooting style to leave the camera in Manual and use the AFL button to achieve focus and then recompose and shoot the way I want. Highly recommended technique in my opinion and after just a few sessions of shooting with the camera it will become second nature to you.
    MuMinded
  17. drb5
    drb5 New Member
    Nov 25, 2012
    38
    It still doesn't really help moving objects though...
    I don't find the C and S terrible in low light for static items, as long as you catch an edge and hold the camera still, but for my 16 month old, it will not lock focus and take the shot fast enough. And that's regardless of focus selection.
  18. RichC
    RichC Member
    Mar 24, 2012
    104
    17
    I'm finding the AFL button method to be a good way of working, it is now pretty much second nature.
    Nevertheless, the fact remains, that the camera focussed fine using "normal" S setting prior to the last fw update, now it does not!
    One wonders whether this is a known problem to Fuji and whether they intend to address the problem with a further fw update ???
    We shall see. :blink:
  19. EyeForget
    Apr 10, 2012
    2,234
    478
    USA & Switzerland
    I had a call into Fuji and they called me back today. Missed the call but will speak to them tomorrow. If they have anything substantive to offer, I'll post it.
    I'm surprised this did not come up earlier. Is it evf only? Otherwise there are enough xp1 users out there that I would think its been known for a while. I started with 2.01 on the 35 with an xe1. My comparative base was the X100 which can lock pretty much all the time in situations the 35 (using the shutter button) was hopeless. M mode is fine, so I now shoot using the AF/AE button.
  20. RichC
    RichC Member
    Mar 24, 2012
    104
    17
    Likewise, I find it strange that it hasn't come up before. I hadn't noticed it because I had spent some time working with a Sony NEX and hadn't touched the XP1 until a couple of weeks ago when I started this thread.
    The lack of contributors to this thread might also suggest that it is only happening to a few of us(?) I wonder.
    Let us know what Fuji say...... if anything!
