Cleaning your camera sensor
Discussion in 'Troubleshooting' started by jknights, Feb 12, 2014.
  1. jknights
    11,629
    2,209
    If you have a Fuji camera with a removable lens then the following cleaning tips apply.
    Please note that this cleaning is done at your own risk but if you follow the instructions then everything should be safe and you will get a clean sensor.
    View attachment Fuji_Sensor_Cleaning.pdf
    If you need help or have questions about this then please post against this topic and we will answer.
  2. errol afed
    errol afed Member
    Oct 23, 2013
    114
    Philippines
    Thanks for posting
  3. wyldberi
    wyldberi Premium Member
    Feb 13, 2013
    919
    164
    u.s.a.
    I use Isopropyl alcohol as a solvent to clean the thermal paste off CPU's when I'm refurbishing a computer. It does a good job on that, and also when cleaning the gunk left behind on dishes and glassware by those sticky price labels that don't like to come off.
    It might work for cleaning the glass filters mounted on sensors, but I don't think I'd trust it for that. Isopropyl alcohol can leave behind a residue. The methanol, or methyl alcohol mentioned would be my choice for cleaning the sensor filters; less chance of leaving the surface contaminated, which is why science laboratories specify methyl alcohol.
    Treat that task the same as you would cleaning a good multi-coated lens: only use enough cleaning fluid to dampen the surface layer of glass; you don't want to soak the surface and have it drip over the edge.
    I'm not familiar with the Re-air product. I think Giotto makes a blower that includes a filter at the air intake to screen out dust particles. I'd rather use this to help dry the alcohol if I don't want to wait for it to air dry.
  4. nwcs
    nwcs Former Gear Addict
    Aug 6, 2013
    1,819
    495
    Tennessee
    I'd be a bit hesitant to use a Q Tip because of stray fibers being left behind.
  5. wyldberi
    Feb 13, 2013
    919
    164
    u.s.a.
    I agree with you, though I imagine it would be possible to see such a fiber on close inspection, which you would want to do anyway after cleaning the filters that cover the sensor.
    I usually buy photographic filters from a website: <2filter.com>. I was browsing there last night and noticed they sell some items for cleaning sensors filters, in addition to the regular type lens cleaning stuff they stock. It's all probably the same thing. But they had one or two items listed as pre-treated cotton swabs. Now, a Q-tip is a brand of cotton swab. But there are other brands. And I've seen some swabs in physician's offices that are mounted on sticks 8" - 10" long. I think these may be made from a denser layer of cotton that would resist having any of the fibers becoming detached and left behind. Perhaps; perhaps not.
    I just noticed that in my previous post above I said something about being frugal with the amount of alcohol used when cleaning the glass filters mounted above the sensor. I failed to omit that you do not want to apply any type of cleaning fluid directly to that glass. You DO want to apply any cleaning fluid used using something like a swab or a lens cleaning paper that has been slightly dampened with the fluid. Just trying to keep the record straight, here.
  6. Graham C
    Graham C Active Member
    Nov 17, 2013
    174
    30
    East Yorkshire, UK
    A device that I have found invaluable is the Visible Dust Artic Butterfly. It gets rid of much more dirt then an air blower and can often save you doing a wet clean. I have also found the Pentax sensor cleaning kit to be excellent and very easy to use.
  7. marsmail
    marsmail Premium Member
    Jul 18, 2013
    550
    79
    GB
    I have as yet not needed to wet clean my XE1 sensor.
    I have cleaned my Nikon D300s several times, using the Visible Dust swabs and cleaning fluid.
    It is a slightly scary job first time round, but then you realise that it is not actually all that easy to damage the sensor, provided you work carefully and leave the big hammer out of the job!
    A viewing Loupe is a necessity for checking that the job has gone OK and an illuminated one makes it a lot easier.
    Others recommend other cleaning products - I can only comment on what I have used - it does the job.
    marsmail
  8. PenGun
    PenGun Premium Member
    May 21, 2013
    563
    107
    BC Canada
    There is a piece of glass protecting the sensor. It should be no more dangerous than cleaning a lens.
  9. Keith Towers
    Keith Towers Premium Member
    Oct 6, 2012
    3,427
    1,268
    Isle of Wight, United Kingdom
    I haven't cleaned a sensor in a few years now, but when I had the 5D Classic it was a monthly chore for five solid years. I just used a rocket blower and a SensorKlear pen and found it all that was necessary to get a good clean sensor. Advisable to go gently with the rocket blower (gentle puffs of air) or you can kick up a vortex of dust inside the camera. I agree with PenGun, it's no different to cleaning a lens or filter and they should always be cleaned very carefully too.
    lysander likes this.
  10. danielsabourin
    danielsabourin New Member
    Sep 24, 2014
    Montreal, Canada
    Something strange just happened to my 56 mm 1.2
    While changing lenses from my 23 f 1.4 to my 56, suddenly, the aperture click stop of the lens stopped clicking. They were clicking right just a few second before. The lens was not droped or anything.
    I looked at the back of the lens and I don't see any lever or something that could have been displaced. All my other lenses work fine.
    Any idea?
    Daniel Sabourin
  11. Dobson
    Dobson Premium Member
    Mar 28, 2014
    1,250
    668
    Butte, Montana, USA
    Maybe this will help. It's not too scary.
    http://www.fujix-forum.com/index.php/topic/26715-35mm-surgery/
  12. jknights
    11,629
    2,209
    I gave the choice so people can obtain usable/safe solvents. If you use high quality products (100% pure or better yet ANALAR) then they have no residues.
    The Giotto Rocket is my preferred system for people who are trained by me as they are easily purchased. I purchase the Re-Air in Philadelphia 10 years ago. I am not sure that it is available these days.
  13. jknights
    11,629
    2,209
    I understand your reluctance but any stray hairs will be blown away in the last air blowing by the Giotto Rocket.
  14. mnflycaster
    mnflycaster Premium Member
    Nov 24, 2013
    641
    309
    Minnesota USA
    pec pad, sensor wand, eclipse... doesn't get any easier.
    Clean my sensors every month this way.
    Too many videos and methods... choose one and have fun!
    How to clean your digital camera sensor
