Custom Settings
Discussion in 'X100F, X100T, X100S, X100, and X70' started by peteg, May 10, 2011.
  1. peteg
    peteg New Member
    May 10, 2011
    Hi, only just found this board so this is a first time post. I've had my x100 for a few days now and im really loving it, save for some of the identified niggles in the UI. One thing that confuses me is that once i've selected one of my custom settings and its in use, how do you de-select it - eg get out of the custom setting and back to default settings??
    Have i missed something obvious? I didnt see it in the manual.
  2. nirvana
    nirvana New Member
    Apr 27, 2011
    You cannot "de-select" a custom setting. Instead, consider the custom settings as "saved settings". You can save current settings to "setting slot" 1 to 3, or edit them in place. When you choose to apply a custom setting, the camera actually LOAD its data and overwrite the current setting.
  3. galumay
    galumay Member
    Apr 8, 2011
    118
    19
    To add to that, when you start all 3 custom settings are set to the default settings, they only change when you edit the settings and save them, so if you havent saved all 3 custom settings with new settings then the unchanged ones retain the default settings.
  4. peteg
    peteg New Member
    May 10, 2011
    Ok, thanks for that. I was reverting back to default settings by selecting an un-assigned custom setting - but that uses up one custom setting leaving only two. Is it just me that thinks having a revert to default function would be quite useful?
