Exposure changes when zooming even in fully manual
Discussion in 'Videography' started by harrisdpi, Apr 21, 2017.
  1. harrisdpi
    harrisdpi New Member
    May 20, 2015
    Has anyone else noticed that the image exposure changes when zooming in or out while filming, even though ISO, aperture, shutter speed and white balance have been locked down?
    If so, is there a way around it?
    When I get a chance I will post an example.
  2. Gaston
    Gaston Premium Member
    May 15, 2014
    299
    97
    Val-d'Or
    Normal if your lens doesn't have a fixed aperture... like the 18-55 or the 55-200 for example...
  3. Goldingd
    365
    76
    First answer, well actually a question first, is what particular zoom lens? If is one with a variable aperture, then that is fully expected.
    Second answer, if it is a fixed aperture (aka constant aperture) zoom lens, then that depends upon the quality of the optic design.
    Note, I am not talking about depth of field.
    Incidentally, focus can change as well (depending on quality of optic design)
  4. SausalitoDog
    SausalitoDog Premium Member
    May 1, 2011
    1,132
    311
    Sausalito, CA USA
    Depends on the lens. Many of the fuji zooms change aperture as they zoom.
  5. Shadowside
    Jun 24, 2013
    1,100
    840
    Winnipeg, Canada
    In addition to the valid points already mentioned...
    Even if the lens has a fixed aperture your metering method will be affected by a change in content, for example if using average or matrix as the content changes so will the average EV, if using spot this can also happen as you zoom in your meter is less influenced by surrounding luminance.
    If you want to test the variance for this with you meter you will need an even (large) light source and a large consistent surface (wall),. focus at infinity (manually) and be within a meter of the wall (or so). Do your test with a high enough ISO setting to allow for hand held speed (meters are less accurate at either extreme end of their range) and stop down one stop to reduce the effect of vignetting changing at different focal lengths.
    When you are all done this test, read an article on the ISO-Less sensor like those used in Fujis. :)
    ISOless Photography With the Fujifilm X-Series
  6. starlights
    starlights Premium Member
    Feb 23, 2014
    872
    401
    DC
    Is your observation based on reviewing actual footage or just what you noticed through EVF while filming? What mode is your EVF set to? Is it possible that its only the EVF compensating ? Try setting it to the non-studio mode (I am forgetting what is it called in the camera menu)...
    If, as stated, your aperture, SS and ISO is locked down, then the only reason your exposure will change while zooming "out" with a variable aperture zoom such as 18-55 or 55-200 is if your aperture is locked down at the widest and you were zoomed in to a focal length where the available aperture was smaller than the value locked down. In this case while zooming out the camera will try to set it to the widest aperture that is locked down and now becoming available as your zoom out. Lock your aperture value to one of the constantly available apertures and you should not see this phenomenon.
  7. starlights
    Feb 23, 2014
    872
    401
    DC
    The metering should not affect the exposure if the aperture, SS and ISO are all locked... should it? Otherwise what would be the point of using all manual while filming? Unless I misunderstood and you were referring to how EVF handles it, not the actual recording
  8. Shadowside
    Jun 24, 2013
    1,100
    840
    Winnipeg, Canada
    Correct, it shouldn't affect the exposure if the camera is on all manual. However, if you are testing the meter of the camera (as I wrongly assumed was the OP's point here) there are many things that will affect the meter that are not as 'fixed' as we think they are. :)
    Sorry to distract, I will go back to hockey and my scotch lol...
