Fuji 90 f2 might be melting camera(s)
Discussion in 'Troubleshooting' started by Glovernotafighter, Nov 19, 2016.
  1. Glovernotafighter
    Glovernotafighter Member
    Nov 19, 2016
    First post - so I might screw this up.
    Anyway, if you can see the photo of my X-T2 then you can see the melting that has occurred after using the 90 F2. Yes I do shoot onto the sun but not for long exposures and I'm careful (knowing that live view in mirrorless means the sensor is always being exposed while the camera is on) not to spend too much time shooting the sun.
    I would have thought that if it was a case if the sun being magnified it would melt the sensor and not the frame around it (the sensor appears fine)
    The worst part is that I just switched to the X-T2 after going through what I thought was two xpro2's that had melted parts inside near the sensor! And it might be my/the lenses fault!
  2. Glovernotafighter
    Nov 19, 2016
    Just so you know what I mean by shooting pics of the sun here is an example so everyone doesn't think I'm crazy! IMG_20161107_083914.jpg
    PBJello, CWRailman, Topsy and 2 others like this.
  3. Macmodus
    Macmodus Premium Member
    Dec 7, 2013
    967
    2,063
    Apeldoorn, Netherlands
    Seems more like a melted lubricant?
    you would be able to remove or is it in the material?
  4. Glovernotafighter
    Nov 19, 2016
    No I agree that the photo looks like it's wet but if you feel it its the plastic that's melted (it's completely dry and I doubt it could be scraped off.)
  5. Glovernotafighter
    Nov 19, 2016
    Hmmmm...
    I looked at it again and I guess it could be lubricant but would that dry to the point where it was completely solid I wonder?
  6. Macmodus
    Dec 7, 2013
    967
    2,063
    Can show you pictures of the inside edge of the XF90. is there something to see?
    How open is the lens on the inside? Could it be?
  7. Glovernotafighter
    Nov 19, 2016
    No I checked with a pretty powerful led light to see if anything looked amiss and the lens looks perfect (although I don't recommend looking at any lens that closely with an led light because you see how dusty everything is ) - I also just took the time to check all of my other lenses just in case and they look fine too.
    Also - thanks for trying to help, I've never posted before and I really appreciate your quick responses!
  8. AusPhotoHiker
    AusPhotoHiker Premium Member
    Feb 22, 2012
    1,208
    187
    Australia
    If it was the bright focussed light of the sun causing problems, it would be impacting an area it was focussed on, not an off image area.
    The mess below the sensor looks like dried goop. Has the X-T2 been laid on it's back in the heat of the day with the lens on? Maybe the lube becomes more liquid then and drips off the lens onto that area. Sure looks like drips not focussed sunlight.
    archisan likes this.
  9. nivaun
    nivaun Member
    Oct 10, 2012
    29
    Quilcene, Washington. USA
    Seems like Fujifilm is who you should be asking. This is very strange, especially where it has dripped to. Can’t think of too many places a lubricant or an adhesive can drip from if your camera is at the angle you show in the sunset photo. Especially if the exposure isn’t long enough to really heat anything up. I guess lubricant from the OIS mechanism could be a possibility.
  10. Glovernotafighter
    Nov 19, 2016
    Yeah the more we talk about some sort of dried liquid the more I think you guys might be right.
  11. ordinaryimages
    ordinaryimages Well-Known Member
    Aug 31, 2011
    129
    79
    Kentucky Bluegrass
    Looks topical to me, I've had no issue with this lens. The post above seems on the mark.
  12. JohnX
    JohnX Member
    Jul 3, 2013
    95
    17
    Have you posted this before, here or anywhere else?
    If not, I've seen this self same issue posted in the past 4-6 weeks, but can't remember where.
  13. Jeff123
    Jeff123 Premium Member
    Feb 11, 2014
    350
    110
    Colorado USA
    I think you really need to go to Fuji support with this. Hard for me to tell from the image but that material does not look like it is melting of the mount material but rather some other material dripping onto it.
  14. JRJ
    JRJ Well-Known Member
    Feb 27, 2015
    176
    206
    Vancouver
    I can't really contribute to the topic at hand, but that's a nice photo.
  15. Glovernotafighter
    Nov 19, 2016
    No I haven't posted on here or anywhere else. It has happened to me before as I mentioned with two other xpro2 s but on those bodies what ever it was also dripped onto the sensor which was even worse.
  16. Glovernotafighter
    Nov 19, 2016
    Thanks!
  17. jamie allan
    jamie allan Premium Member
    Aug 2, 2014
    1,116
    1,055
    Glasgow Scotland
    It's hard to say with a 2 dimensional image - but I'd guess that that looks like some form of liquid spatter. There appear to be 5 distinct areas and if you look at the middle one and the right hand one they both continue up into the stepped area towards the sensor - as if it's a liquid dribble. Have you tried removing it with say a cotton bud and a bit of isopropyl alcohol ? I'd try that but make sure you are sparing with the fluid and only rub gently. I've no idea where it could have come from if it is dried liquid. Just a guess but could it be sea spray from changing lenses at the shore?
  18. jknights
    11,736
    2,264
    That looks like a liquid that has dried or molten substance that has solidified.
    I dont think it has anything to do with the type of photos you take.
    Nice photo of the heron at sunset BTW.
    So I think I would follow Jamie's suggestion to see if you can dissolve some of it away using a damp cotton bud using isopropyl alcohol as the solvent. Do not use something like acetone!
    I think you should email a photo to Fuji info@Fujitec.com asking them what they think is happening. You will need to tell them lens model, camera model and possibly serial number so they can do a check.
  19. Glovernotafighter
    Nov 19, 2016
    I tried the isopropyl alcohol but it doesnt seem to have any effect
    I think If it is liquid then its melted and has beCome part of the plastic because its rock hard
    Here's a photo of the area after cleaning: (if it looks different then I think that's just my crappy lighting job)
  20. jknights
    11,736
    2,264
    I think I would now give the sensor a quick clean with a Giotto Rocket blower or the like and check the sensor is clean. If not then do a wet clean.
    This is my method Cleaning your camera sensor
    However others may prefer their own method or derivations. As long as the sensor is clean then that is good. Clean sensor is important in your images.
