Fuji X Pro 1 + 18-55 , great combination
Discussion in 'X-Pro2 and X-Pro1' started by peterleyenaar, May 11, 2013.
  1. peterleyenaar
    peterleyenaar Member
    Dec 19, 2012
    96
    Kimberley B.C. Canada
    Returned recently from an extended trip to Europe, I had with me the X pro1, 18-55 , 35 mm 60mm , the last 2 stayed in the bag, only used the 18-55
    with great results, in musea, outdoor, everywhere, also had with me the Leica X2 which also performed well, not as versatile, but IQ on par with the X Pro1.[​IMG]
    Liam likes this.
  2. PeterPrism
    PeterPrism Active Member
    Jan 6, 2013
    226
    Italy
    Super RED !
  3. Liam
    Liam Premium Member
    Mar 8, 2011
    663
    121
    Ireland.
    Woaaa! Striking colour, and great resolution into the far distance. To know your workflow would be interesting please?
  4. peterleyenaar
    Dec 19, 2012
    96
    Hello Liam,
    Thanks for the compliment,
    My workflow in LR
    All corrections are minor and subtle
    1) Auto exposure, then correct manually
    2) Bring back highlight sllder for more detail
    3) Fill out histogram so you have data from 0 to 100 using black and white sliders and holding the option key on mac
    4) use shadows slider for more detail
    5) Adjust WB
    6) Apply small amount of sharpening, between 20 and 40
    7) Luminance noise correction if required around 10
    8) Presence adjustments
    Done
    Occasionally I apply the gradiant filter and the color corrections : hue, saturation and luminance, careful and sparingly.
    I looked at your images (very beautiful ) , some have some detail missing, in particular the image of the Inislaucht chuch, the trees could use more detail, using the shadow slider and the skye
    would benefit from cutting back the highlights and the gradiant filter, only very minor adjustments required and at this level it might only be a matter of personal taste.
    Best Regards
    Peter
  5. Liam
    Liam Premium Member
    Mar 8, 2011
    663
    121
    Ireland.
    Thank you Peter. Your care and attention to each aspect shows. Very beautiful.
  6. sc_john
    sc_john New Member
    Apr 24, 2013
    South Carolina, USA
    When using the 18-55 (on X-Pro 1), are you effectively limited to using EVF... or does the OVF frame somehow adjust to the zoomed focal length? Thanks.
    John
  7. Rob MacKillop
    Rob MacKillop Active Member
    Mar 20, 2013
    64
    32
    Edinburgh
    Stunning reds!
  8. Arjay
    12,774
    4,616
    No, you're not limited to the EVF. You can just as well use the OVF - the OVF's bright frame will adjust with zoomed focal length. You need to manually switch OVF magnification however.
  9. sc_john
    sc_john New Member
    Apr 24, 2013
    South Carolina, USA
    Thanks! There is definitely an X-Pro 1 in my future.
    John
  10. refiningman
    refiningman Premium Member
    Nov 16, 2012
    1,394
    468
    North Texas
    If I could offer a couple of suggestions:
    1. Do WB correction as step #1
    2. Do Noise Reduction before Sharpening.
  11. peterleyenaar
    Dec 19, 2012
    96
    Liam asked me for MY workflow, that is it, please feel free to give him your workflow.
    If you make alternate suggestions, you should mention why.
    I don't think your suggestions are valid , here is why :
    Address exposure, detail and histogram data range BEFORE WB, can't evaluate colour on improper exposed images or images lacking detail or images that do not have the full histogram data range
    Apply noise reduction AFTER sharpening, sharpening can induce noise that needs to be corrected.
    I am just replaying to your post, this is not the place to get in to a discussion about LR image processing.
  12. peterleyenaar
    Dec 19, 2012
    96
    Here is an Image of one of Rembrandt Van Rijn's paintings that I took in the Rijks Museum in Amsterdam, dimly lit, with the Xpro 1 and the 18-55 , this camera and lens perform flawlessly
    under all circumstances.[​IMG]
  13. peterleyenaar
    Dec 19, 2012
    96
    Here are some images of Vincent Van Gogh's paintings. taken in the Van Gogh Museum under difficult and low light circumstances with the Xpro1 and 18-55.[​IMG]
    [​IMG][​IMG]
  14. Liam
    Liam Premium Member
    Mar 8, 2011
    663
    121
    Ireland.
    Competently done Peter, and the more I see of that lens the more I appreciate it.
  15. refiningman
    Nov 16, 2012
    1,394
    468
    North Texas
    OK no problem, you do it your way.
  16. peterleyenaar
    Dec 19, 2012
    96
    If you wish to discuss the rational of your LR workflow, please go to the Fuji X post processing forum and open a new thread, I'll be happy to share the rational
    of my LR workflow, please let me know.
  17. Jannie
    Jannie Premium Member
    Jun 24, 2013
    1,007
    683
    Seattle, WA
    So, I've seen comments here about the 18-55 being soft at the telephoto end, and I've seen comments that it's a great lens overall, but in those negative cases the question was brought up as to whether the shutter speed was too low or the IS wasn't turned on. These things can really make a difference, none of which are the lenses fault. So my question still is: in general, is this considered an okay lens, a good lens, or a great lens? I'm still undecided as to what will be my next lens and slowly selling off my DSLR Canon gear to finance it as I already know that the XPro-1 is going to be my go-to camera from here on.
  18. MuMinded
    MuMinded Premium Member
    Jun 20, 2012
    545
    372
    Japan
    Hi Jannie,
    I have the XPro1, the 18-55 and the 55-200. I also have the 35mm and the 60mm. I always take on-line lens reviews very lightly.. without knowing the exact methodology used to test the lens all on-line samples are pretty much useless. So, it will all come down to you either getting to a camera shop and testing the lens you are interested in, or place some trust in the brand that you are purchasing based on your experience. Some of that trust can be based on remarks picked up here an there. To that end, let me add my remarks for you.
    The 18-55 is a fantastic lens as far as the build quality goes. The 55-200 is the same. You would have no regrets with the quality as far as that goes. For me, the 55-200 is the lens that has allowed me to completely retire my DSLR equipment. The 18-55 lens is every bit as good as my equivalent Nikkor in that range and the 55-200 is likewise, just as good as my Nikkor 80-200, albeit with a slower max F-stop.
    So far I have been pleased with every XF lens I have purchased with maybe the 60mm being the exception. The 60mm only disappoints because of the AF performance, not the image quality.
    From your posts It seems that you are really enjoying your Xpro-1.. I think that your enjoyment for this camera will only be enhanced by the XF lenses and if there are any low points they will be minor and your joy of being ride of the DSLR will help you easily overlook them. :)
    It's been said before, but what good is premium glass if it's just too darned heavy to have out in the field with you.. These XF lenses will save your shoulders and encourage you to bring them with you, which is the whole point, isn't it?
  19. redfred
    redfred Premium Member
    Jan 25, 2012
    314
    55
    Worcestershire, UK
    Hey Mu,
    Would you say that the lens redeems itself if you want it for portraits and not macro? What I'm getting at is, for portraits, I'm almost never looking for super-quick AF becuase I''m taking my time to engage with the subject.
    Thx, Kevin.
