Godox Ad200 and X1-C transmitter
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by leesearlephotography, May 19, 2017 at 7:00 PM.
  1. leesearlephotography
    leesearlephotography New Member
    Nov 5, 2016
    Cornwall
    Just thought you all maybe interested to know that i did a test using the Godox canon transmitter and AD2200 on my fuji x-t2. Check out the video here interested to hear your thoughts. Its my first video so go easy on me.
    Paul20 and Filenest like this.
  2. Jonimages
    Jonimages Premium Member
    Nov 19, 2014
    447
    261
    Silverhill-AL
    Ok, I will be gentle as possible. I couldn't get through the video because I found myself skipping to get to something about how to use the new Godox with a Fuji system that I just gave up. If you want to grow a YouTube channel stick to the topic and get to it quickly. I wanted to see how the systems work together if they can, or give a demonstration of the settings used, or examples from a photoshoot but I gave up after about 30 seconds of skipping. You may have all that in there but if I have to work that hard, I'm just going to the next video. Editing and retakes are your friend.
  3. Fujiphotog
    978
    564
    I agree with jonimages. Your first 5 minutes could be deleted with no loss of information. The entire video could be done very well in 5 minutes rather than 13+.
  4. bobbyzfx
    bobbyzfx Premium Member
    Sep 30, 2014
    1,276
    230
    SF Bay Area
    I was hoping that you found a way to make that AD200 work in HSS with X1 on Fuji.
  5. leesearlephotography
    Nov 5, 2016
    Cornwall
    thank you for your feed back :) much appreciated, ill take on board the tips and make the next one better :) I did waffle on a bit :p
  6. leesearlephotography
    Nov 5, 2016
    Cornwall
    appreciate you taking the time to send a reply, all tips taken on board the next video will be on point :)
  7. elisha.jesudason
    elisha.jesudason Member
    Apr 28, 2017
    27
    Any trigger that just uses the center pin will work. The problem is HSS and TTL are not sent trough the center pin alone.
  8. leesearlephotography
    Nov 5, 2016
    Cornwall
    Hopefully it wont be long to wait :) My moneys on Godox releasing the first HSS TTL trigger for Fuji
  9. elisha.jesudason
    Apr 28, 2017
    27
    Cactus already has the V6 II but apparently very fiddly. I'm still planning on getting it with the RF60X but I may wait a little longer for either the Nissin fw update to enable HSS or Godox if they come out with one.
  10. F2Bthere
    1,943
    974
    Adorama is already taking preorders on a Fuji version of a Godox flash which can act as a trigger. Adorama is a solid player (and the preeminent Godox reseller in the US), so I take this as a solid indication we will have support for Fuji vary soon.
  11. leesearlephotography
    Nov 5, 2016
    Cornwall
    Thats good to hear :) Bring it on, although im in Cornwall UK so its going to have to be ebay for me :)
  12. elisha.jesudason
    Apr 28, 2017
    27
    Hopefully they release a full blown transmitter which can control other Godox flashes in HSS. Wireless TTL would be nice too.
    The flash they are releasing is extremely underpowered.
    leesearlephotography likes this.
  13. leesearlephotography
    Nov 5, 2016
    Cornwall
    personally Im going to hang on for the X1-F to come out. Im happy with manual triggers until then :) Rumour are pointing towards June July time
  14. jknights
    11,991
    2,361
    I feel the same but the Cactus v6 mkii whilst working is somewhat fiddly.
  15. elisha.jesudason
    Apr 28, 2017
    27
    I'm surprised that Yongnuo hasn't jumped on the Fuji bandwagon at all.
    I had a Yongnuo CTR-301p 433Mhz transmitters in 2008/2009 for the Sony/Minolta hotshoe mount. And that was when people were questioning whether or not Sony was serious in the DSLR market.
  16. leesearlephotography
    Nov 5, 2016
    Cornwall
    Id just like to add, the Godox Service and support side are pretty poor. I recently ordered an item and they sent a completely different item to what i ordered. Trying to resolve it is a but of an issue. Id hate for something to go wrong, I dont like the thought of trying to register a repair with them.
  17. Jonimages
    Nov 19, 2014
    447
    261
    Silverhill-AL
    That's one of the reasons I like to buy the Adorama versions of Godox products.
  18. leesearlephotography
    Nov 5, 2016
    Cornwall
    Im not sure who the UK supplier would be or even if there is one at the moment.
  19. David Loh
    David Loh New Member
    Today
    Hi Lee. Did you have to update any firmware on the transmitter or the AD200 or change any settings on the X-T2 to get it to work?
  20. leesearlephotography
    Nov 5, 2016
    Cornwall
    Yes you have to change the hot shoe into single pin mode. Have you got one ?
