Gordy's neck strap/X-Pro 1 questions
Discussion in 'Fuji X Accessories' started by wilburpan, Jul 6, 2012.
  1. wilburpan
    wilburpan New Member
    May 22, 2012
    63
    A few questions for all you Gordy's strap users out there:
    1. Neck pad or no neck pad?
    2. Given the issues with lug wear, split ring or string ends?
    2a. If you answered split ring, strap bumpers or not?
    Thanks!
  2. Hassebasse
    Hassebasse Well-Known Member
    May 21, 2012
    102
    74
    Denmark
    Hi
    I use a Gordy's adjustable strap (no neck pad) and find it my best camera strap ever! I simply love the quality (and look I have to admit) of it. Mounted the rounded rings.
    Note! since it is kind of squared shape it will not move around easily on your chest. I like that but some may prefer a smooth strap instead
    I can only recommend it.
  3. stormhalvorsen
    stormhalvorsen Premium Member
    Feb 14, 2012
    298
    40
    I have a sling with a split ring lug mount. It does not require any kind of leather bumper as the metal ring will never come in contact with the camera body! (due to the thickness of the leather where it is connected to the split ring)
    I would say neck pad, yes definitely. Even though the camera isn't heavy. (for a sling you're going to have a place where the ends of the loop are joined anyway). The camera is somewhat light for use with a sling and tends to bounce around a lot. I need to have a hand constantly holding it in place when walking or it will start dancing. I suppose you wouldn't have that problem with a regular strap though.
    If it wasn't for the fact that I now use the Fuji grip, I would possibly have ordered a strap with one end connected to the tripod mount. This would be good as the tripod mount hole is off centered and I think the camera would hang quite nicely on its side that way.
  4. Skulmoski
    Skulmoski Premium Member
    Sep 29, 2012
    272
    31
    Abu Dhabi
    Bump
    I too am undecided whether to order the neck strap with or without the neck pad for my X-Pro? What's your opinion?
    GJS
  5. Arjay
    12,633
    4,524
    Thread moved to accessories section for better searchability.
