Instax SP-1 not connecting well with X-T2
Discussion in 'Troubleshooting' started by mnflycaster, Nov 21, 2016.
  1. mnflycaster
    mnflycaster Premium Member
    Nov 24, 2013
    641
    309
    Minnesota USA
    I am still trying to get consistent results printing to the SP-1.
    First I have to turn off my smart phone to have any luck at all.
    After 3-4 tries I can get it to connect and print from the SP-1... then when I go to another frame the connection locks up and I have to take the battery out of the camera and try to reconnect... I have to reset the wireless connection every time to have any luck connecting... I hope fuji will fix this in the next firmware. My X-T1 still does it consistently without a problem... I am hoping it is just a wi-fi bug.
    This is what I posted last week in the Fuji X-T area. I got no replies.
    OK... My instax SP-1 printer works with my X-T1.
    My X-t2 is struggling.
    I have found threads for the X-Pro2 with similar issues.
    I followed the advice of taking the battery out of the printer and then doing the Shooting Menu Reset and Set-up Reset on the camera. Then re-entering the SSID and pin 1111 (default) on the X-T2 and powering back up the Instax.
    It worked for me once.... then never again. I have tried 5 times to replicate the initial success.
    Every time the camera freezes on the initial search for the printer. I have to take the battery out to restart. I have tried turning the camera on first and searching for a printer (printer on and printer off)... I have tried turning the printer on first then the camera and searching. Same result... The first only time it connected feels like a fluke. Needless to say I spent a few hours on this.
    The fuji remote app still works fine on the X-T2.
    My X-T1 still prints fine to the instax.
    Is this a hopeless endeavor?
    Is there a fix? Firmware?
    Am I just crazy? (Don't answer that! )
    Any help or advice is welcome.
  2. Scott Grant
    Scott Grant Premium Member
    Jun 30, 2013
    594
    477
    Newfoundland
    Either the x-t2 or X-pro2 has a bug whereas they connection must timeout the first time you try to connect. It takes a few minutes. Once it times out it should connect on the second try. Give it a try! You have nothing to loose.
    mnflycaster likes this.
  3. SithTracy
    SithTracy Premium Member
    Apr 6, 2014
    310
    116
    S.E. Wisconsin, U.S.A.
    Had this issue with my X-Pro2 until fw 2.01. Perhaps it will be addressed in the first X-T2 firmware update.
  4. mnflycaster
    Nov 24, 2013
    641
    309
    Minnesota USA
    We shall see what the future brings! The second try unfortunately did not help... Thanks for the tip though!
  5. mnflycaster
    Nov 24, 2013
    641
    309
    Minnesota USA
    Today's newest firmware update cured it!!!
    Thanks Fuji! :)
