Instax SP-1 printer, flashing and non responsive
Discussion in 'Troubleshooting' started by Cb1, Jan 10, 2017.
  1. Cb1
    Cb1 New Member
    Jan 10, 2017
    Hoping someone can help! My Instax SP-1 printer is having some issues. It was working fine, and then I replaced the empty film for a new one. It loaded normally and printed out the black top film, but then all the lights (battery, printing strip, number of photos left) started flashing green. They do not stop flashing, the printer does not respond to the on/off button. The batteries were fine (3 lights full green) so I am not sure what the issue is. I have tried removing and replacing the film in complete darkness. Once I close the back nothing changes. The flashing continues and it doesn't make any noise or seem to register that the film is there. I have had to remove the batteries to stop it from flashing. It's outside of it's year warranty so unfortunately fujifilm wouldn't be able to replace it. Any advice is greatly appreciated!
  2. pfogle
    pfogle Puzzled
    Nov 20, 2013
    1,093
    694
    Auckland New Zealand
    Have you tried another cartridge? Or putting the old one back in? If it still doesn't work, then it's the printer...
  3. Cb1
    Cb1 New Member
    Jan 10, 2017
    Thanks for getting back to me! I tried putting in the old cartridge as you suggested, but the flashing continued and nothing changed. It was even flashing when the printer had no film in it at all. It's just strange because it was working completely fine but the effect was immediate once i put the new film in. Any other suggestions before I write it off as broken?
  4. mnflycaster
    mnflycaster Premium Member
    Nov 24, 2013
    641
    309
    Minnesota USA
    Even though the battery indicator show full bars it might be off. Are the batteries brand new?
    I had some batteries that were close to being done do the same thing to me. I replaced with new and all was well.
    I also had an issue once where a cartridge was bad. Replaced with a new one and all was well...
