Lens for X-T20
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by double00, Mar 20, 2017 at 4:16 PM.
  1. double00
    double00 New Member
    Mar 7, 2017
    New owner of an X-T20 here and wondering what lenses those with this camera are using. I am coming from Nikon D7100 with 35mm, 16-85, 300mm lenses and mostly shoot general photography, i.e., travel, street, and I enjoy some macro, etc. I like the Fuji size and image quality much better than Nikon.
    The X-T20 is rather small and some of the larger lenses would seem to be unbalanced on the smaller body. Although I have not tried any of the larger lenses on the T20, so I can't say for certain.
    I currently have the 18-55 that came with the camera. The 27 pancake, to me, is a natural for the T20. Curious what other lenses those that have this camera are using and believe work great with this size body?
  2. Blazer
    Blazer Fuji Commander
    Jan 5, 2013
    3,116
    677
    Baton Rouge, LA USA
    two options for you... 1) add the 18mm and new 50mm to your 27... great 3-lens "compact prime" kit for the X-T20... or 2) add the 14mm and 55-200 zoom to your 18-55 for a larger full range 3 lens kit... so many choices... so little cash! good luck.
    jdenlinger likes this.
  3. Narsuitus
    1,195
    473
    Assuming you liked the Nikon lenses you were using, I would get the 55-200mm and a 35mm to go with the 18-55mm Fuji lens you already have.
  4. double00
    double00 New Member
    Mar 7, 2017
    I did like the Nikon lenses I was using. I was mostly concerned with the size of the T20 not being able to handle some of the larger Fuji lenses.
    I have not handled the 50-200 is it similar in size to the 18-55. Would it be unbalanced on the T20?
    Which of the XF35mm lenses are more suitable for the T20? I liked the Nikon 35 because it was a fast lens, 1.8 for low light situations.
    Is the XF23 at 1.4 smaller than the 35 1.4? If so, I would not be opposed to the 23 - 35 in FF. Pictures of the XF35 1.4 looks as if this lens is fairly large.
  5. Narsuitus
    1,195
    473
    I cannot comment on big lenses used on small bodies because I have no problem using full-frame Nikon lenses on APS-C bodies or micro 4/3 bodies.
    Also, when I use a lens that is bigger and heavier than the body, I usually do not shoot handheld. Instead, I mount the lens on a tripod or monopod and then attach the lightweight camera body to the lens. I never mount the unbalanced, front-heavy, lightweight camera body directly to the tripod or monopod.
    However, if the size of the 35mm lens is important, you may want to consider the smaller Fuji 35mm f/2 instead of the larger Fuji 35mm f/1.4. Or, you may want to consider the smaller Fuji 23mm f/2 instead of the larger Fuji 23mm f/1.4. Personally, I prefer the f/1.4 version because I need the extra light gathering more than I need a smaller lens.
  6. nwcs
    nwcs Former Gear Addict
    Aug 6, 2013
    1,819
    495
    Tennessee
    There are many good options. Which lenses you should consider should be something you see from he focal lengths you use often. Take a look at that first before buying a bunch of stuff. It's easy to get a lens that's cool but you'll never use. Don't get anything just because someone did a nice pic with it.
    The 18-55 is a good start. I suggest trying it alone and see what you're missing out on and then buy. There really aren't any clunkers in the lens set. But I think the new f2 primes and the 55-200 are lenses to consider.
    MontyBigglesworth likes this.
  7. Robmas4229
    Robmas4229 Premium Member
    Mar 13, 2015
    549
    222
    Florida, USA
    Narsuitus likes this.
