Long exposure NR
Discussion in 'X-Pro2 and X-Pro1' started by markopa, Apr 13, 2012.
  1. Arjay
    12,774
    4,616
    Could this mean that the long time NR threshold shutter speed is dependent on ISO values? Does anybody have indications for this assumption?
  2. jlaronge
    jlaronge Premium Member
    Mar 22, 2012
    456
    139
    I suspect you're right on this assumption. I tested at ISO 200, 30sec. @f16 and ISO 6400, 2sec. @ f16 both of which allow the same amount of light to reach the sensor. At 6400 the LENR kicked in while at 200 it didn't. LENR didn't kick in at ISO 200 until 1min. 15sec.. I supposed you could go through each ISO @f16 and find the shutter speed at which it will kick in.
    f_random likes this.
  3. Arjay
    12,774
    4,616
    I just ran a test series with varying ISO values, all at f16, with the following results for fastest shutter times at which LENR is kicking in (all @ T, except for 200 ISO which was @ B ):
    ISO 200: 1min 10s
    ISO 400: 30s
    ISO 800: 15s
    ISO 1600: 8s
    ISO 3200: 4s
    ISO 6400: 2s
  4. flysurfer
    flysurfer Premium Member
    Aug 14, 2011
    3,239
    687
    NUE
    Makes perfect sense to me. 2^6 s = 64 seconds, which pretty much equals the 1 min 10 sec. at ISO 200.
  5. jlaronge
    Mar 22, 2012
    456
    139
    This makes perfect sense. All are essentially the same exposure except for the ISO 200. Since ISO 200 is the native ISO for the sensor (and highest quality), that's probably why the extra exposure is allowed.
    Two questions:
    Does the dynamic range setting have any effect on this?
    Are the results better using a lower ISO without LENR?
  6. flysurfer
    Aug 14, 2011
    3,239
    687
    NUE
    Not as fas a I have seen.
  7. cbwerner
    cbwerner New Member
    Apr 10, 2012
    39
    I hear you, but it may be that you do not need to be concerned - let me try explaining.
    1. With a given sensor, the level of dark current noise noise is affected by 3 variables - ISO/gain, exposure duration, and the temperature of the sensor. Temperature is neither measurable or controllable with this camera so I'll set it aside (astro CCDs generally include a thermoelectric cooler that will cool to 35-40C less than ambient).
    2. Dark current at a given ISO will vary linearly by exposure duration, i.e., 2x exposure gives you 2x noise. I'm going to guess that at a given exposure, that ISO will also affect the level of dark noise linearly, but I'm assuming that ISO 6400 requires twice the current as 3200 and so forth.
    3. Dark current noise is one of four sources of noise in digital photography; readout/bias noise is actually the largest source of noise in digital sensors in most shooting situations.
    4. The type of scenes where we're getting into high ISOs and long durations are dim (yeah, duh :D ), or said another way, have a low signal to noise ratio. Thus the dark current noise becomes most problematic in shooting situations where not only is the dark noise at it's highest levels, but the signal in the scene is also at very low levels. So without reduction, the resulting image has a very poor S/N ratio, and therefore, sucks.
    I'm guessing based on what's reported in the thread that Fuji has made an engineering decision that dark current reduction does not have a noticeable impact on S/N ratios except where they have enabled it, and therefore it's not worth compromising the shooting in other scenarios. They might be wrong, or we might disagree with how they implemented it, but that would actually be an easy thing to test. I'd do it myself, but unfortunately, I can't yet count myself in the ranks of X-Pro 1 owners. Hopefully soon. :)
  8. andymu
    andymu Member
    Apr 24, 2014
    88
    Glasgow UK
    Since the 2nd image doesn't actuate the shutter, say you take a 5 minute exposure,
    Then when the camera is doing the 2nd 5 minute image, does the camera need to stay on a tripod for this?
    Reason I ask is, if it didn't need to stay on a tripod during the 2nd exposure I could swap a different camera on to the tripod while this happens and do other work
