My first Fuji, X100F! Question about power management...
Discussion in 'X100F, X100T, X100S, X100, and X70' started by Shuffles, Apr 20, 2017.
  1. Shuffles
    Shuffles New Member
    Feb 21, 2014
    Hi FujiX forum,
    So, the other day I finally received my first Fuji camera, a silver X100F. So far, I love it. Now waiting for some accessories, like case, filter adapter etc.
    I have a question that hopefully someone can answer. In the Power Management menu, there is an option for High Performance, and when I compared it to the Normal setting I didn't notice any obvious difference.
    What exactly does that setting do, and is it worth using? I assume it uses up the battery faster.
    Thanks.
  2. khunfred61
    khunfred61 Well-Known Member
    Mar 7, 2014
    184
    54
    france
    "Faster AF, better EVF, shorter battery life." RTFM;)
  3. SausalitoDog
    SausalitoDog Premium Member
    May 1, 2011
    1,132
    311
    Sausalito, CA USA
    With all of the 100 series, I've always just turned the High Power on so I can't say how much more battery life you get with it off, but it's always wise to have an extra battery and I want the fastest focus I can get...if you really know you won't need it, turn it off, I guess...
  4. Shuffles
    Shuffles New Member
    Feb 21, 2014
    If you RTFM (page 123 in English PDF), it does NOT say the AF is faster in high performance mode than standard. In fact, it says it's the same as standard. The only apparent differences are "better" EVF and more battery drain.
    But, what exactly is better about the EVF? How much shorter is the battery life? I understand if no one knows, but figured maybe someone on this forum might.
    But according to the manual the AF is not faster in high performance mode. It's the same as standard.
  5. khunfred61
    Mar 7, 2014
    184
    54
    france
    There are 3 levels, everything is clear (which is not always the case in this manual). AF is slower in eco mode, "frame rate" drops when no operating, and a better EVF means (IMO) a faster refreshment frequency. That said, some choices are obvious (MF = no need faster AF).
    Try by yourself. If you can't find a difference, it's about 1/100 second.
  6. SausalitoDog
    May 1, 2011
    1,132
    311
    Sausalito, CA USA
    Well, I can't argue with the manual, so I guess I leave it on for the better EVF... the point is, I want the most out of the CAMERA, not the battery !
  7. khunfred61
    Mar 7, 2014
    184
    54
    france
    About battery life (even if strangely tests for another lens...)
  8. Badabing
    Badabing New Member
    Mar 17, 2017
    NRW, Germany
    Hey there,
    don't know exactly where I read this....
    There should also be a kind of 'special sleep mode' for 15 or 20 minutes in High Performance, when the camera is turned off, that does decrease boot up time when powered on again. Probably someone else knows more about this?
  9. Shuffles
    Shuffles New Member
    Feb 21, 2014
    Thanks to all who replied. Seems like it's just worth experimenting. I love using the OVF so maybe for me the standard setting it fine.
  10. tinoboston
    tinoboston Premium Member
    Feb 24, 2014
    317
    59
    Boston
    No it's not. Keep it in High Performance all the time. Just do it :)
    rayvonn likes this.
