My first X-Pro1 image samples
Discussion in 'X-Pro2 and X-Pro1' started by flysurfer, Feb 17, 2012.
  1. flysurfer
    flysurfer Premium Member
    Aug 14, 2011
    3,239
    687
    NUE
    Since pre-production samples of the X-Pro1 keep getting better, we can finally say a bit more about its image quality.
    As I have been in possession of such a camera and a lens kit for almost a week, I was happy for the opportunity so test the X-Pro1 on a professional set in Poland: the Railroad Museum in Warsaw.
    However, we are still talking pre-production with several known and documented hard- and software problems that will be corrected in the final for-sale cameras and lenses.
    These samples are OOC JPEGs that I uploaded on Flickr via iPhoto. Except for some cropping, angle leveling and very minor brightness adjustments, there was no JPEG post processing. The color settings remained entirely untouched.
    The Railway Museum is obviously located next to some railroad tracks. So there was an opportunity to take a snapshot from the bridge with Velvia film simulation:
    35mm, ISO 800 (DR400), f16, 1/420
    As you can see from the Auto-ISO values, the camera chose DR400 dynamic range expansion for this shot.
    On the set, I had several opportunities to test the skin tone reproduction of the X-Pro1. IMHO, the new negative film simulations come in handy here, especially "Pro Neg. Hi".
    60 mm, ISO 400 (DR200), f3.6, 1/1400, +0.3 EV
    As you can see, there's no moiré, even though the camera lacks a low pass filter. Resolution and sharpness are pretty impressive.
    60 mm, ISO 400 (DR200), f3.6, 1/1500, +0.7 EV
    Dynamic range is quite terrific, as illustrated by the following shot that also featured critical white balance. Lighting was 5500 K outside and 3300 K inside, so I manually set the X-Pro1 to 4000 K when developing the JPEG in-camera.
    18 mm, ISO 800 (DR400), f5.6, 1/150
    Here are a few portrait shots with the 35/52 mm standard lens, slightly stopped down to f1.8:
    35 mm, ISO 800 (DR400), f1.8, 1/1000, -0.3 EV
    35 mm, ISO 800 (DR400), f1.8, 1/1200, -0.3 EV
    35 mm, ISO 800, (DR400), f1.8, 1/1400, -0.7 EV
    Last but not least a shot with the 60 mm portrait/macro lens:
    60 mm, ISO 400 (DR200), f3.6, 1/140, -0.3 EV
    Watcher24 and PraxisPictures like this.
  2. flysurfer
    Aug 14, 2011
    3,239
    687
    NUE
    Let's continue with some close-ups of railway miniatures. For these shot, I resorted back to my proven Astia film simulation:
    35 mm, ISO 200 (DR100), f1.8, 1/160, -0.7 EV
    Manually forced DR100 renders saturated colors, but also shows burned-out lights. In this case, this is quite tolerable, though.
    Here's the same motive shot with the 60 mm macro lens:
    60 mm, ISO 800 (DR400), f3.2, 1/140
    Again the 35 mm prime:
    35 mm, ISO 800 (DR400), f3.2, 1/80, -0.3 EV
    Here are a few details from this motive shot with the 60 mm lens. The first shot is stopped a bit more, but needs ISO 3200 in return:
    60 mm, ISO 3200 (DR400), f6.4, 1/40
    As you can see, a barely managed to hold 1/40s w/o IS.
    Here's the same train with open aperture:
    60 mm, ISO 800 (DR400), f2.4, 1/160
    Let's conclude with a snapshot of the miniature railway:
    60 mm, ISO 2000 (DR200), f.2.4, 1/90
    PraxisPictures likes this.
  3. robert
    14,794
    4,689
    Really like the 60mm rendering...Zeiss-like. Impressive performance and DR.
  4. hunz
    hunz Premium Member
    May 27, 2011
    423
    Why no f1.4 shots from the 35MM? c'mon post some up!
  5. LincolnLogs
    LincolnLogs Premium Member
    May 10, 2011
    1,383
    90
    Las Cruces, NM USA
    I really like the results from the 60mm too! Colors are amazing! I can see a lot of possibilities with bokeh with that lens!
  6. MattPowell
    MattPowell Member
    Oct 12, 2011
    119
    The 35 and 60 look like outstanding lenses. I've been worried about the 18mm, but that one f/5.6 shot looks better than similar-aperture shots I've seen elsewhere - I hope that means it's sharper at f/2 and 2.8 than we've seen in other photos.
  7. hunz
    hunz Premium Member
    May 27, 2011
    423
    the 18mm has too much distortion of the periphery - whether this will be fixed with software in-camera or not, has yet to be seen, but from the photos i've seen from it to date - its not stellar
  8. TheRoadWarrior
    TheRoadWarrior Member
    Apr 22, 2011
    227
    21
    Oxford, UK
    Congrats on the images, there are some fantastic shots there! Were you using studio flash for the early headshots of the guy ?
  9. disign
    disign Member
    Mar 10, 2011
    117
    Nice photos, I see that You had some good time with the camera. Share some more on handling, what impressed You, and what not?
    As far as lenses go, the 35 and 60, are really top class. 35 is a true must have lens. The 18 mm definitely is a lens with soul, needs to be worked out. More like the older standard 28/2.8 lenses, rather than the heavy wide-angle "landscape" zooms. It's a small pancacke "do it all" lens, not a resolution monster like the zeiss 21/2.8.
  10. jknights
    11,995
    2,362
    Nice images FlySurfer.Love the 60mm portrait and also the detail macro. The pictures with the 35mm f1.4 also look very sharp.Need to look at them on something with a screen larger than my ipad so I can assess properly but images look good for pre-production firmware with issues.I guess they need to get everything ready for release in next month.
  11. flysurfer
    Aug 14, 2011
    3,239
    687
    NUE
    No, I just made sure his head exactly covered the large tungsten backlight. So I got my own sun on this not so sunny day. ;)
  12. flysurfer
    Aug 14, 2011
    3,239
    687
    NUE
    Sure having a good time, it's always nice to have your own set with your own personal settings, fast SD card and tailored Zeiss diopter. So obviously my pics look a bit different from those of others who had to use generic equipment with generic settings (or even worse: settings changed by the guy who used it a few minutes earlier). So I feel lucky.
    As for handling, it's very much like a X100. MF is much better, of course. AF is okay, too, its real-life performance depends on several factors, one being the skills of the photographer.
  13. whtchocla7e
    whtchocla7e Member
    Oct 8, 2011
    153
    Great photos.
    Tells us more about MF though. Most people are probably dying to know.
  14. robert
    14,794
    4,689
    It's pre production, and Fujifilm may have limitations on what info can be shared.
    Thanks very much for posting these images!
  15. LincolnLogs
    May 10, 2011
    1,383
    90
    Las Cruces, NM USA
    Flysurfer,
    You mentioned image stabilization. What's the story on the IS(image stabilization)? Did you set to auto in your custom setting? You probably didn't need any IS with the 18 or 35mm, but with lower light and the 60mm, I imagine it was helpful.
    I didn't realize that many of those images were taken at really high ISO-amazing results, considering. I looked hard for moire or digi noise, but couldn't really find any. The bokeh possible with the 60mm makes me think of some of the special Leica lenses. People will be taking portraits with the eyeball in focus and the nose looking like a fuzzball! :) I'm still trying to figure out how the MF works for the macro on that lens? Did you find it difficult to do macro? Because of the focal length, my first choice in lenses would be the 18mm, but the 60mm is looking pretty impressive.
    You are one of the few early users, did you get any impression as to when the production models will be(really) available for us mortals? I'm hoping they are geared up for real production and not letting the camera out in dribs and drabs. I think there will be plenty time to save up for this beast! :)
  16. JSRockit
    JSRockit Premium Member
    Mar 8, 2011
    846
    72
    Which 18mm lenses, priced at $600 or less on the market, don't have distortion?
  17. robert
    14,794
    4,689
    There is one 18mm pic in this thread, and nothing in that photo is out of the ordinary with regards to distortion.
  18. hunz
    hunz Premium Member
    May 27, 2011
    423
    i can see it. take another look.
    and where are shots taken @ f1.4 on the 35mm? - one doesn't buy an f1.4 lens b/c they want to use it at f1.8 or f2.0. or is it just not that good? just like the X100. the lens is great at f2.8. but at f2.0 - it ain't that great. just telling like it is.
  19. robert
    14,794
    4,689
    To me, looks like any 28mm wide angle would look.
  20. hunz
    hunz Premium Member
    May 27, 2011
    423
    I just found some shots taken at 1.4 on the 35mm. looks like same photoshoot event as flysurfer was at..
    http://www.lenstip.com/1969-news-Fujifilm_FinePix_X-Pro1_-_sample_images.html
    the 35mm isn't too bad wide open..
    and killer high ISO performance. that 6400 train shot looks like 3200 or even 1600 on the X100. so, at least a 2-stop advantage
