Problem: X-T2 spot metering only with manual focus!
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by Gunkanman, May 18, 2017 at 6:41 PM.
  1. Gunkanman
    Gunkanman New Member
    Apr 29, 2013
    Copenhagen
    Hi.
    My X-T2 appears to have developed a problem. Basically it will only spot/centre meter in manual focus mode. Has anyone else experienced this?
    I have reset to factory settings but still the problem persists.
    I guess I need to send it back to Fuji for repair?
  2. merosen
    merosen Active Member
    May 20, 2014
    134
    32
    Somerville, MA
    Are you talking about spot metering or spot focus (the box in the middle of the finder)
    On the X-t1 in manual there is a single box in rthe middle of thr finder. It's a single focus point as opposed to multiple focus points.
    You can move the box around with keypad, change it size with the wheel on the back of the camera. Spot focusing is the only option in manual
    The box represents the AF Mode
    Menu 1 >Autofocus setting> AF Mode,
    Spot metering is a different function. Metering isn't effected by setting the camera to manual
    I'm assuming its the same on an X-T2
  3. beakhammer
    9,482
    5,616
    I think there is a way to couple and uncouple metering from this focus point box.
  4. Gunkanman
    Apr 29, 2013
    Copenhagen
    Got it working again. If 'Face Detection' is switched on, then spot/centre metering won't work with Auto or Continuous focus.
  5. Richard_R
    5,847
    4,756
    I discovered the same thing when I first got the X-T1. Very frustrating at the time and I could not for the life of me figure out what was going on.
  6. David Schneider
    David Schneider Premium Member
    Nov 16, 2012
    2,355
    838
    NJ, USA
    If you reset to factory defaults as you said, doesn't that take you off Face Detection? I haven't done a re-set myself so just wondering. Thanks.
  7. Gunkanman
    Apr 29, 2013
    Copenhagen
    Strange that things like Face Detection remained on. Only the assignments of the customised buttons, etc changed.
