Shutter Lag - Verdict
Discussion in 'X-Pro2 and X-Pro1' started by markopa, Jun 3, 2012.
  1. markopa
    markopa Premium Member
    Sep 12, 2011
    487
    As announced I've tried to measure the shutter lag. This could be done in two ways without being intrusive into the camera:
    a) Each camera action consumes battery power. That said one could measure the current drain from the battery. The current waveform directly follows the camera actions. However this approach is more com0plicated as you have to solder few wires t othe battery plus teh current waveform could be smoothed by the internal electronics capacitors and power managment circuitry.
    B) The second method is by recording the sounds. Every mechanical action of the camera emits sound. By recording the sound and measuring the intervals one could figure out what the camera is doing. And that was the method for measuring shutter lag.
    Below is a typical audio footprint of the cpro1 taking a shot. Camera setting were:
    - MF, prefocusued
    - Manual expsure 1/4s
    - EVF
    - ISO1600 (manual)
    - Latest camera and lens firmware, 35mm lens
    So let examine the audio fingerprint:
    The part highlighted by the red circle is the xpro1 taking an exposure:
    Taking into account the sampling frequency of 44100 samples per second we can observe the exposure time:
    The grayed region is approx 11132 samples which leads to (1/44100)*11132 = 252ms. So we are pretty accurate as our manual exposure time was set to 1/4s.
    Moving further we can measure the part before the exposure - the shutter lag:
    Again, the grayed region is 2132 samples which yields to a shutter lag of 48ms. Hum. Not as declared, but not so bad.
    So why I'm missing shots if the lag is only 48ms ? Lets examine again the first audio fingerprint. We can notice tow small dots after the exposure has been taken. Intrigued by this I started to observe what the xpro1 is doing in that moment ? Yes, those are the blades returning after you depress the button.
    We can observe this movement after the first and second exposure. After each exposure I was again half pressing the shutter button preparing the camera for the next shot. So far so good. But, hey ? What happening after the third exposure ? The blades were not returned into the typical position, but just half of the operation was performed by the xpor1. Whoups ? :blink:
    Bankg ! Pressing the button in such situation the xpro1 has to first move the blade to its final position and than take the shot. Let's measure the "lag":
    There are 9924 samples grayed which leads to 225ms. Ajajaj ! :huh:
    Verdict:
    - The shutter lag is contained below 50ms
    - For some reason after you take one shot you don't allow the xpor1 to take its time and settle down, but you half press the shutter button as soon as you can an anomaly happens which results in a consequent lag of 225ms after you press the button all the way down. An eternity.
    - Not confirmed, but it looks we have also a ~100ms of the delay in the EVF. I can't measure this, but is there for sure !
    - If you have noticed we have about 1 to 3s between each shot. Pretty slow.
    Fuji :angry: ?! Its time to release a firmware fix for this as I'm missing decisive moments and my kinds are growing !!!
    Watcher24, jknights and flysurfer like this.
  2. flysurfer
    flysurfer Premium Member
    Aug 14, 2011
    3,239
    687
    NUE
    Could it be an unintended side effect of the now much slower aperture dance? Aperture adjustmend used to be faster (and noisier) before the "hysteria" surrounding "aperture chatter" hit the net and prompted Fuji to roll out a (maybe too) quick fix. So is is this "fix" actually a new bug?
  3. EvilTed
    EvilTed New Member
    May 20, 2012
    21
    I've noticed this too.
    If you prime the lens by half-pressing the shutter button, sometimes it just goes off and takes the picture?
    ET
  4. flysurfer
    Aug 14, 2011
    3,239
    687
    NUE
    I made some unscientific tests involving a "fast" 18mm version 1.00 lens and a "slow" 18mm version 1.01 lens and could not notice any difference in shutter response once the camera was primed. That said, both lenses need some time after taking a shot and immediately half-pressing the shutter button to re-prime the camera. However, I can't notice any differences between both lenses with this respect.
    Using an adapted M mount lens reduces the "prime time" between shots, meaning you can take several single shots in a row more quickly.
    All three tests involved MF and manual exposure mode.
    I any case, once the camera was primed (= green ready light next to the VIEW MODE button), there was no significant shutter lag.
  5. Arjay
    12,632
    4,521
    Thank you for your thorough tests, Markopa!
    I have observed this after-shot lag effect on the X100 too. It doesn't stop me from getting the 'decisive moment' on the first go, but it certainly does for consecutive shots.
    It's very strange that Fuji gave up one of the cooler features of the X100 here: On the X100, the video frame rate is boosted considerably when you press the shutter button to the first pressure point, effectively at least halving EVF lag. Why on earth did Fuji do away with this feature on the X-Pro1?
    Hm - we don't know yet if this after-shot lag is due to a software or hardware deficiency. If it were due to hardware, we'd have to wait for an X-Pro 1 Mk II. :(
  6. Machspeed
    Machspeed Member
    May 16, 2012
    Thank you markopa for this well-thought test!
    At least it somewhat proves that the shutter lag is a common issue with these cameras and not some statistically insignificant occurrences.
  7. Heuves
    Heuves New Member
    Jun 1, 2012
    What a great job. Have the fujiguys given a reaction yet?
  8. Ivophoto
    Ivophoto Member
    Sep 8, 2011
    214
    Flanders
    I didn't need this test to know. Just using the cam was enough. But this test proves things. It surely explains the inconsistency I'm talking about, and that is the most irritating thing. Especially if you are in snipe mode. I didn't understand why I was not able to anticipate on the lag, the inconsistency is the reason....
  9. markopa
    Sep 12, 2011
    487
    Thanks !
    As for now they didn't. At least I'm not seeing a firmware release :) Joking....
    Let's hope they notice this and possibly fix it.
  10. Machspeed
    Machspeed Member
    May 16, 2012
    markopa, in your wave graphs, can you identify the moment the shutter release button is fully pressed? Not the moment the camera begins the exposure but the actual moment you are achieving full shutter release button press.
    I guess not (because it's not a very audible event).
  11. markopa
    Sep 12, 2011
    487
    You've yourself partly answered. If fact is hardly audible. If you take a closest look at the last wave you can notice something is happening before the camera tries to move the blades.
    However I didn't wanted to take also this into account as I think is really minimal. Seems the lag itself is not a problem. The problem seems to be inconsistency. On the other side the lag is not within specifications given by Fuji - correct me if I'm wrong.
    [BTW: I'm really tempted to prove/measure how the battery management is bad designed (and not worth the ~1500€ the camera costs) as the battery indicator doesn't work as it should be. But let's us leave this for another thread.]
  12. Machspeed
    Machspeed Member
    May 16, 2012
    Mike Kobal just posted on the shutter lag in his blog post.
    "Shutter lag in manual focus mode: this problem could easily get fixed with the next firmware upgrade.
    Even in mf and full manual exposure mode, Fuji lenses assume a resting position until the shutter is half pressed. This causes significant shutter lag. Take the Sony Nex 7 for example, it lacks a manual focusing/DOF scale, however, once you focus, set aperture and shutter speed, the lens stays in the prefocused position and holds the selected aperture value. There is practically no shutter lag with this setting. Once I spot a subject or scene, I half press and hold the shutter button until I am ready to take the picture. This eliminates shutter lag completely, if I miss the shot I can’t blame the camera. "
  13. Sergio
    Sergio New Member
    Jul 29, 2011
    82
    The published shutter lag is 0.05 seconds, which seems to be in line with your test results. This is from the X-Pro brochure.
    X100 is 0.01 but Leica M9 is 0.08
  14. flysurfer
    Aug 14, 2011
    3,239
    687
    NUE
    Leaf shutters vs. focal plane shutters. M9 has the additional handicap of a larger shutter for a larger sensor, so no wonder it is even slower.
  15. jknights
    11,433
    2,133
    Yes indeed the use of Audacity to capture the camera sounds and to analyse these results is very good.
    Thanks Mark. Much kudos.
    Is it possible to measure the AF performance in a similar/some way?
  16. Ivophoto
    Ivophoto Member
    Sep 8, 2011
    214
    Flanders
    Stop comparing a Leica M with a X camera, please.
    A Leica M is in first place a camera and in second place a electronic contraption, a X camera is in first place an electronic contraption and in second place a camera. And that makes a huge difference for some.
  17. jknights
    11,433
    2,133
    And I thought both were either photographic tools or male jewelry
    :lol:
    aquaCA likes this.
  18. Ivophoto
    Ivophoto Member
    Sep 8, 2011
    214
    Flanders
    :D Fair enough, it is Leica's own fault to attract shuch comments. :D
  19. jknights
    11,433
    2,133
    I was going to ask for an Xpro1 upgrade so that it had an OVL, EVL, and a rangefinder for MF. Then it really would be a ground breaker.
    I still love the old split screen rangefinder focussing. So easy to use except in very dark conditions.:)
  20. jknights
    11,433
    2,133
    That is what we want is a set of XL lenses. X = xpro. L= leaf shutter.
    Maybe a 23mm and 50mm would be great!
