Wrong exposure
Discussion in 'Troubleshooting' started by Thue, Dec 20, 2016.
  1. Thue
    Thue New Member
    Dec 20, 2016
    Hey.
    Hope you can help, because my pictures are getting way to bright. I have a X100 with an update 2.21. In Auto-mode it works perfect and if I adjust the shutter speed, it will regulate with the aperture and ISO, for making a right exposed picture. The problem is when I go manual at my aperture ring, then the pictures get too bright.
    I've added five pictures, where I go from
    1) "Auto Aperture, ISO 800, Auto Shuttter"
    2) "2.0, ISO 800, A"
    3) "2.8, ISO 800, A"
    4) "4, ISO 800, A"
    5) 8, ISO 800, A
    Shouldn't my camera take a slower shutter speed, but expose the picture correct (+0)??? What could be wrong? my settings? or something mecanical?
    Hope you can help, thanks!
  2. Richard_R
    5,430
    4,057
    If you go to manual the camera will use whatever settings you select. That is what manual is - manual.
    I think you are choosing settings that over expose.
    lawsofphysics likes this.
  3. Goldingd
    288
    56
    (Edited for spelling embarrassments and an follow-up)Actually, he is not the n manual, he is allowing the camera to adjust the shutter.
    Question, without me saving the images and then looking at the metadata, not at a pic just now, what were the resultant shutter speeds?
    Follow-up
    Ok got off by butt, got on a PC to look at metadata, but, nope, metadata striped, no F-stop, ISO or Shutter speed info.
  4. JD_Bugs
    JD_Bugs Active Member
    Oct 6, 2016
    65
    28
    Oregon, USA
    Yes, check the exif data for each image and see if the shutter speed is changing.
  5. Goldingd
    288
    56
    Someone with an x100, is bracketing limited to 3 shots? (Ok, read a manual, only 3 shots, so not bracketing ) Somehow the progression of the above shots seems wrong, why indeed would an overexposure be occurring. If somehow the shutter is not changing then an underexposure would occur, my logic all screwy? Hmmm, something is being overlooked.
  6. Goldingd
    288
    56
    OP, please open your images in LR (or whatever post processing app you use) and write down the f-stop, ISO, and shutter speed for each image, and report back. Somehow this all looks a bit backwards. Scratch head.
  7. DanGleabols
    DanGleabols Well-Known Member
    Feb 28, 2014
    139
    57
    Halifax, UK
    Isn't there a batch of x100 with aperture problems, oil or something.... An aperture that was stuck and not closing down would cause this issue. The camera would be setting the shutter speed and iso for the set aperture but then the picture is taken at f2. I can't tell on my phone if the dof increases across the set of pics. Technically, it should also happen in full auto mode too. However, if you use the x100 anything like I used to then 9/10 times the camera would set the aperture wide open if left to its own devices!
    Goldingd likes this.
  8. dem
    dem Premium Member
    May 31, 2015
    361
    164
    Looks like SAB - sticky aperture blades. The camera needs to be serviced.
  9. Goldingd
    288
    56
    Ahh, interesting, that leads to the following link via google searching:
    Buying a Used X100 – How to Avoid Sticky Aperture Blade
    Note that the article talks about some possible copies that mighty have a problem based on S/N
    and
  10. streetsntravel
    563
    259
    This has the look of the SAB, Sticky Aperture Blade, syndrome that plagued the early X100. We would need to see the pertinent EXIF data to be sure but Dan is on the right track. This looks like a fortuitous choice of f/2 to begin the sequence and the camera does it right, now continually setting the camera at smaller apertures and the camera is increasing shutter speed to compensate for the user setting, but the lens is unable to perform the stopping down action to make it all right. My X100 was beset by SAB on an important trip and I was able to salvage some photo ops by setting the camera to f/2, appropriate ISO and hoping max shutter speed would get it right, later realized you could also use the built in ND filter to extend the picture taking conditions. It wasn't till after that trip when I was "back on the net" that I discovered that my camera was one of the chosen.
    If that is indeed the problem, it is fixable. Mine was fixed under warranty and is still working, but failing for other reasons now after 1000s of pictures. It may be now that repair is certainly out of warranty and costs may be more than a replacement camera.
    I don't want to cause angst to the OP, but full info could help sort this out.
    Roger
  11. tbhv55
    tbhv55 Premium Member
    Jan 30, 2012
    271
    31
    Devon, UK
    Yes, I agree with the previous comments ... this looks like SAB. It's pretty much identical to the behaviour displayed by my x100, which resulted in it going back to Fuji for a SAB repair around four years ago.
  12. bjorke
    bjorke Premium Member
    Aug 30, 2014
    302
    147
    San Francisco & the surrounding planet
    I didn't realize this was a tech discussion, I looked at the pix and thought you were downing Guinness until blind....
  13. roalk
    roalk Premium Member
    Apr 27, 2013
    528
    210
    Queensland, Australia
    The depth of field in all the images appears to be identical. To me this supports the theory about it being a sticky aperture blade problem!
    tbhv55 likes this.
  14. tbhv55
    Jan 30, 2012
    271
    31
    Devon, UK
    Yes, the identical DoF was something that I observed when I was testing my x100 for SAB - and the OP's images show the same characteristics.
  15. Thue
    Thue New Member
    Dec 20, 2016
    Thanks a lot for the answers! There is no doubt it's the sticky aperture blade issue..
    My camera doesn't move the blade at all :/ only works in auto mode, where it typical chooses 2.0.
    Here are the shutter numbers: (all shot in auto shutterspeed)
    1) "Auto Aperture, ISO 800, Auto Shuttter" - 1/90
    2) "2.0, ISO 800, A" - 1/90
    3) "2.8, ISO 800, A" - 1/50
    4) "4, ISO 800, A" - 1/25
    5) 8, ISO 800, A - 1/6
    The question is if I only can use it in Auto mode from now on or if it can be fixed (a tutorial or something) or the only way is past the fuji office??? Getting it fixed by Fuji, would cost a lot of money, right?
    I have the receipt, but from the old owner.. maybe its possible for him to hand in and get the warranty
  16. Ozarks
    Ozarks Well-Known Member
    Jun 19, 2015
    229
    151
    Arkansas, USA
    @streetsntravel is correct. That looks like what I experienced with sticky aperture blades on my X100. I bought it from KEH and they quickly accepted a return.
    Repair could be costly, @Thue, so you're left with getting it repaired or using it at f/2 and faster shutter speeds and/or the neutral density filter. It's still good at f/2, but what a bummer. If you just bought it recently may you can get a refund.
  17. streetsntravel
    563
    259
    IIRC, the problem showed up around 2000 frames. At the time the net was abuzz with a search of serial numbers, shutter counts, etc. It was a while before Fuji acknowledged the problem, but then there was that preponderance of data.
    At this point, maybe a phone call to Fuji. Not all Fuji locations are as friendly as others. I'm really sorry you have to thread yourself through all this, so much uncertainty and my experience is unfortunately tainted by one particularly unpleasant individual - someone who shouldn't be working in any customer interfacing position, anywhere. I wish you the best, but if it is going to require the cooperation of someone else, I'd try to do it as quickly and as openly as possible. If there are any roadblock discoveries to be made, it might as well be now than later.
    Roger
  18. tbhv55
    Jan 30, 2012
    271
    31
    Devon, UK
    On a more positive note - and counter to the service that streetsntravel suffered - Fuji UK's response was commendable when I sent my x100 in for SAB... I couldn't fault them.
    This doesn't, of course, alter the facts of streetsntravel's experience, and I have certainly heard some horror stories elsewhere on this matter, so the situation is not uniform across all Fuji locations.
  19. DanGleabols
    Feb 28, 2014
    139
    57
    Halifax, UK
    @Thue it's definitely worth contacting Fuji about getting an idea about the price of repair.
    Using it in the mean time, your better off using a setting where you control the aperture (aperture priority/manual etc) but leave the aperture set at f2. Auto isn't going to be reliable, as soon as you try and use the x100 in good lighting (outside) you'll probably find it'll then try and use smaller aperture sizes and your exposure goes astray.
  20. Thue
    Thue New Member
    Dec 20, 2016
    Thanks for the help. I'm going to repair it at Fuji. Just want to tell you that in Denmark the cost for SAB is 1000DK and it's around 133€. Thanks again!
