X-E2 burst mode shooting?
Discussion in 'X-E1, X-E2, and X-E2S' started by ryan00013, Nov 7, 2013.
  1. ryan00013
    ryan00013 Well-Known Member
    Feb 17, 2013
    202
    46
    Oklahoma
    I'm curious about how the X-E2 handles in burst mode shooting in comparison to the X-Pro1. Basically, I am hoping the X-E2 performs the same way as the X-100s and basically every other camera, in that I can shoot a single photo in burst mode and simply hold down the shutter anytime I want a burst.
    When set to burst mode (both 3fps & 6fps), my X-Pro1 will automatically shoot two images with a single shutter press. This is annoying for a few reasons:
    1. Extra time and effort to sort through image sets.
    2. Louder shutter sound (I do a lot of documentary/street shooting)
    Does the X-E2 exhibit this same behavior? Or will the camera allow you to take only a single frame if pressing the shutter button a single time in burst mode?
    *note I know about the trick of "pressing the X-pro1 shutter button lightning quick" and it will only take one. This feels strange to shoot this way due to shutter lag.
  2. Miyata610
    Miyata610 Moderator Staff Member
    May 30, 2013
    3,068
    916
    Tasmania
    My xe1 shoots a single image if I'm quick with the press. In both 3fps and 6fps.
    Edit....
    Hmmm. Just tried my Contax RX, it's much easier to stop at one. I don't have anything else to compare.
  3. kenbennett
    kenbennett Premium Member
    Jun 26, 2013
    2,727
    1,403
    North Carolina, USA
    I have the same problem. With every other camera I own, I can easily shoot a single frame in the high-speed advance mode, even a 1D Mark IV at ten frames per second. Getting a single frame from the XE1 is basically impossible, unless I do such a quick jab at the shutter that the whole camera is jarred. Not smooth....
  4. ryan00013
    Feb 17, 2013
    202
    46
    Oklahoma
    Right, this is what I am looking to avoid. It feels strange to shoot that way.
  5. Arjay
    12,774
    4,616
    I have never managed to shoot just one frame if my X-E1 is in burst mode. I always get at least two frames. :(.
    I generally try to avoid burst mode because the camera will always display only the first shot of a the burst sequence, and only show the rest of the sequence's pictures after you've pressed the Down Arrow button. Then, you can cycle through all shots of a sequence.
    If you want to see the shots of another sequence, you have to exit from this mode by pressing Disp Back. Only then, you can select the first shot of the next sequence and repeart the operating sequence.
    Tiresome.
    ryan00013 likes this.
  6. AlbertInFrance
    AlbertInFrance Premium Member
    Feb 1, 2013
    838
    195
    Morbihan, France
    If I read the specs aright the X-E2 no longer uses that horrible separate numbering system (sxxxx) and displaying bursts as videos.
    I'm a bit puzzled how other cameras 'know' when you want a single shot. With a burst speed of (e.g.) 5fps I'd expect that any firing pressure longer than 1/5 sec (200ms) would require the camera to fire subsequent shots in a burst. As it's quite difficult to get fingers to react that fast I would be surprised at any camera that behaves the way that some of our excellent colleagues describe above.
    I will admit that the only other extensive experience I have with burst shooting stills dates back to the late 70's, so this is in no way a challenge.
  7. mhuang
    mhuang Premium Member
    Sep 12, 2013
    1,290
    271
    Louisville, KY, USA
    I on the other hand prefer how the X-E1 lumps bursts into a series of frames with only the first one displayed. Makes chomping easier, at least to me it does. :)
  8. kenbennett
    Jun 26, 2013
    2,727
    1,403
    North Carolina, USA
    I think it has to do with the sensitivity of the shutter button. A 5D Mark II at 5 frames per second is trivially easy to shoot single frames, while a 1D Mark IV is a little more challenging, but still much easier than my XE1. It feels like the travel distance of the shutter button from half-press to full-press is very short on my Canons compared to the Fuji, and just a momentary increase in pressure fires a shot. It's barely a conscious effort.
  9. ryan00013
    Feb 17, 2013
    202
    46
    Oklahoma
    Agreed. I have shot with the Canon G1x, T3i, & 5D3; Sony RX-100 & NEX-6; and the Fuji X100s. All of these cameras I was easily able to shoot a single photo while in burst mode. The X-Pro1/X-E1 is a whole other story. A normal shutter press on my X-Pro1 always gets me two photos. This is highly inconvenient.
  10. Alan Cohen
    Alan Cohen Premium Member
    Jun 12, 2011
    318
    106
    I don't do much burst shooting, but I tried it last night at our high school's football game. On 6fps I got some pretty good shots. I had no problem getting one shot at a time. It's just a quick flick of the shutter. If you "press" it you will get two. A quick flick and only one.
    It was night and the lighting was poor. No time to let the camera make any decisions so all settings on manual including focus. 1/250 shutter, f2.8 on my 90mm Contax G and ISO3200. The 55-200 was just not bright enough under these conditions. Fuji really needs a telephoto prime - 100mm f1.8 please!
    [​IMG][​IMG]
  11. jwr
    jwr Premium Member
    Apr 4, 2013
    1,576
    354
    Dallas, Texas
    From a software perspective I would guess that Fuji decides on a burst before the shutter is even pressed and other cameras, although they're in burst mode, don't make the decision until they detect an initial long-press on the shutter.
    I'd also bet that if you had a very accurate method to measure the time period between images, the Fuji's will be consistent between the first and all following shots, while other cameras likely have a slightly longer delay between shots 1 and 2 than they do between subsequent shots.
    Fuji may be figuring that they need all the help they can get to improve their burst rate so they simply turn it on and let it rip. It's like auto-repeat on your computer's keyboard. You can adjust the delay when you setup auto repeat. Too short of a delay and you get two characters regardless of how fast you press and release.
    It is a nuisance and requires a lot more culling in LR.
