X-Pro 2 change ISO on front wheel
Discussion in 'Suggestions for X-Camera Updates & Improvements' started by pandoraefretum, Feb 17, 2017.
  1. pandoraefretum
    pandoraefretum Premium Member
    Jun 25, 2011
    847
    275
    Bristol, UK
    1. Like the X100F, I am hoping for firmware that will change ISO with the front wheel dial (maybe it's called front command dial). I don't hate the current ISO dial, but it would make ISO switching fast.
    2. Also, Auto ISO settings should allow lowest and highest settings to be equal, so you can force AUTO 1 to 200, AUTO 2 to 400 and AUTO 3 to 800 (or whatever values you like).
    Both these options (n2. is easy to implement) should be do-able via firmware only.
  2. liggy
    liggy Camera Fondler
    Feb 22, 2014
    1,218
    590
    PacNW
    Even though I don't mind the X-P2 ISO dial - adding the front wheel functionality for ISO in "C" would be handy. And your idea of setting the "auto" ranges that way would make it a quick way to select ISO. Good ideas.
