X-Pro 2 & VideoMic Pro problems
Discussion in 'Troubleshooting' started by signor, Nov 20, 2016.
  1. signor
    signor New Member
    Nov 20, 2016
    I'm having real problems getting my videoMic Pro working with my X-pro 2.
    I'm using a stereo 2.5 to 3.5mm adaptor but I get no sound when I record. It's also pretty much flat when I'm looking at the mic levels. When I do get a reading, I record but still there's no audio.
    The internal mic works fine.
    Anybody know a way to solve this?
  2. F2Bthere
    1,766
    795
    Can you verify all the pieces in the chain on another device? Does the mic work for recording on anything else? Does it have a battery that isn't working? Do you have anything with a similar plug to test the converter (many phones use them)? Have you tested anything else in the XP2 microphone plug (if no other mic, you could use an earphone as a mike--won't have much power but will at least allow verification of connection and that input isn't faulty)?
    Often basic troubleshooting can reveal where the flaw is.
  3. signor
    signor New Member
    Nov 20, 2016
    Good idea, I didn't think of trying it with earphones. The mic doesn't work on anything else, whether I use the converter or without & I'm using a new battery. I originally thought it was user error or the converter was the problem but just tried the headphones & it works fine, so it looks like the mic is at fault. Thanks for your help.
