X-T1 L-Bracket?
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by RonSmith, Feb 9, 2014.
  1. RonSmith
    RonSmith Premium Member
    Jul 23, 2013
    334
    480
    Michigan
    Any word from RRS about an L-Bracket for the X-T1?
    Alternatively, does any know if their L-Bracket for the X-E1 will work until they come out with one?
    Thanks!
  2. apsphoto
    apsphoto Premium Member
    Apr 23, 2012
    1,599
    633
    Orange county , CA
    I doubt the X-E2 will work, that is just a guess. I am sure they will make one, they seem to support the Fuji, so hopefully they will do one quickly, does not hurt to put in a request. The more requests they get, the more likely they will have incentive to get one done timely.
    Alan
  3. RonSmith
    Jul 23, 2013
    334
    480
    Michigan
    Good idea, Alan. I just sent them an e-mail and received an automated response with a Case Number, indicating that someone from customer support will get back to me.
    I'll post what I hear from them.
    Ron
  4. Richard_R
    5,868
    4,768
    There are plenty of generic ones around. All the OP has to do is some research.
  5. etrigan63
    etrigan63 Premium Member
    Oct 3, 2012
    522
    122
    Miami, FL
    The real question is will they make one for the X-T1 + Grip? They have not done so for the E-M1 or A7/A7r. They only have a bottom plate for the A7/A7r + Grip with no option to "L" it.
  6. sunnysideup
    sunnysideup Premium Member
    Aug 25, 2013
    270
    74
    Iowa
    Do L brackets generally work well when the camera has bays on both sides? How does the vertical part of the bracket not block the bay door from opening?
  7. RonSmith
    Jul 23, 2013
    334
    480
    Michigan
    The vertical portion has an opening allowing access to the ports on the left side of the body.
  8. etrigan63
    Oct 3, 2012
    522
    122
    Miami, FL
    L-brackets place the vertical part on the left side of the camera, not the right where the shutter release generally is. How it interferes with the door(s) on the left side of the camera depends on the design of the doors. I have seen U-shaped and C-shaped brackets (along with the more traditional O-shaped brackets) used for the vertical component. iShoot has a bracket for the X-E1/2 that allows the left side door to be opened but you have to slip something pretty thin in there to pop it open. How this can be done with an X-T1 remains to be seen.
  9. Mapleleaf14
    Mapleleaf14 Well-Known Member
    Aug 10, 2012
    194
    73
    Cincinnati, Ohio
    I for one hope somebody out there makes an L-Bracket for the X-T1 with vertical grip. I have a Kirk Enterprises L-Bracket on my Nikon D4 and it is wonderful...gives me Arca-Swiss compatibily in both landscape and portrait formats, but doesn't interfere at all with shooting handheld in either format.
    I'm going to contact both them and RRS to put a request in.
    I also saw these two "Universal L-Brackets" from ProMediaGear that might work...I had one of theirs for my old Nikon D7000 and it was actually a pretty nice quality piece of kit...
    a 3-inch version - http://www.promediagear.com/3-inch-Universal-L-Bracket_p_134.html
    and a 4-inch version - http://www.promediagear.com/4-inch-Universal-L-Bracket-_p_135.html
  10. etrigan63
    Oct 3, 2012
    522
    122
    Miami, FL
    Tell me how and I will second that request.
  11. Mapleleaf14
    Aug 10, 2012
    194
    73
    Cincinnati, Ohio
  12. etrigan63
    Oct 3, 2012
    522
    122
    Miami, FL
  13. Mapleleaf14
    Aug 10, 2012
    194
    73
    Cincinnati, Ohio
    Really Right Stuff's reply:
    [SIZE=medium] [/SIZE][SIZE=medium]"[/SIZE][SIZE=medium] It doesn't look as though we currently offer a plate for that camera, and we have yet to make a decision.[/SIZE]
    [SIZE=medium] If we decide to make a custom plate for that camera, you will see such an announcement on our Facebook page or in one of our newsletters. In the meantime, here are some generic plate options you could use:[/SIZE]
    [SIZE=medium] MPR-73: [/SIZE][SIZE=medium]http://www.reallyrightstuff.com/s.nl/it.A/id.4524/.f[/SIZE]
    [SIZE=medium] B6: [/SIZE][SIZE=medium]http://www.reallyrightstuff.com/s.nl/it.A/id.2137/.f[/SIZE]
    [SIZE=medium] BPnS: [/SIZE][SIZE=medium]http://www.reallyrightstuff.com/s.nl/it.A/id.2250/.f[/SIZE]
    [SIZE=medium] However, please be aware that because this is a generic solution, there is no guaranteed anti-twist and you might need to remove the plate from the camera in order to access the battery door/memory card slot of your camera body.[/SIZE]
    [SIZE=medium] Please let us know if there is anything else we can help you with.[/SIZE][SIZE=medium] "[/SIZE]
    [SIZE=medium]Maybe with more requests, RRS will decide to add L-plates for the X-T1 and X-T1/Grip combo.[/SIZE]
  14. minivini
    minivini Member
    Jul 4, 2013
    204
    23
    SC
    I've been an L-bracket user through many cameras. I'm also a ball head user. The fact is, I've very seldom used the bracket in its portrait orientation as a notched ballhead allows for the same positioning. In my opinion, an L-bracket is really only useful as a protective piece. They're good at taking a beating, but for the weight and bulk they add, I won't be buying one for the T1 and grip. I'll add a generic Arca-Swiss plate to the grip and the Fuji grip for just the body.
  15. dpt2014
    dpt2014 Dr. J
    Mar 29, 2013
    3,481
    744
    San Diego, CA
    L-Plates are nice because they allow full use of the ball head adjustment while in portrait orientation. When you drop the camera into the slot in the ball head to go into portrait you loose any fine tune adjustments, in other words you might not be able to drop it enough to make it perfectly level. This could be because of uneven ground, or your tripod ins't adjusted right. The bigger problem is all that weight is off axis which makes it extremely hard to move it within the ball head and not have it shift around. With an L plate the weight remains centered over the ball head; flipping the camera and head to get portrait mode gives you a less well-balanced load.
    http://www.reallyrightstuff.com/s.nl?search=video+L+Plate
    jwarthman likes this.
  16. RonSmith
    Jul 23, 2013
    334
    480
    Michigan
    Here is the response I received from Mark Gvazdinskas at RRS ...
    "Thanks for your inquiry. We are currently waiting to get the new Fuji camera in house to design plates/check if any of our existing plates will be a good match.
    We don't know exactly when we'll be receiving the camera. Once we get a camera in house it usually takes roughly 4-6 weeks before plates are in production."
  17. sunnysideup
    Aug 25, 2013
    270
    74
    Iowa
    I was going to purchase a RRS ballhead, panning clamp, nodal slide, and L bracket for my X100, but now that I've pre-ordered the X-T1, I can't. I hope they get one out ASAP!
  18. marcosv
    marcosv Premium Member
    Apr 23, 2013
    444
    57
    San Jose, CA
    Personally I do wonder how well will the X-T1 will perform if you use the portrait feature of some ball heads. Using the smaller primes, the lighter overall weight might be good enough.
    My problem using L-brackets in general is some of the design compromises used to allow better access to the connectors on the left side. Some of those compromises results in an awkward looking plate that makes it harder to use or store in smaller camera bags.
    I plan on buying the Fuji hand grip and seeing how that works out. Since my tripod and ballhead were intended to support my Canon 5D3 with 70-200/2.8 IS, I suspect it'll work, even with the heavier/longer telephoto zooms.
    OTOH, I wonder what happens when you add the battery grip. We're going to need a custom plate to get better anti-twist. So here's hoping RRS does design something for that combo.
  19. apsphoto
    Apr 23, 2012
    1,599
    633
    Orange county , CA
    I have put my request in at RRS as well, the more requests they get the higher in the priority list it will go, so everyone email them!
    As for the l-plate I find them extremely useful I use mine all the time, in portrait and landscape orientation, not having to flip the ballhead 90 degrees is a real benefit and well worth the extra cost of an l-plate.
    Alan
  20. Richard_R
    5,868
    4,768
    A week after RRS release their L bracket companies like iShoot will have generic ones on ebay at a fraction of the price and 90% of the quality.
