X-T2 Custom Settings - v2 Firmware
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by Jack Crouch, Apr 21, 2017.
  1. Jack Crouch
    Jack Crouch New Member
    Apr 21, 2017
    Hi All,
    Can anyone help me with a little problem with the Custom Settings of my X-T2?
    When I bought the camera I could understand the Q Settings section without difficulty.
    Then I changed the firmware to v2.0 and now the Q menu shows up as per the attached image. I cannot scroll through the 7 different sets as before. eg. in v1 the top left box showed the Custom Setting number and the different selected choices. That does not happen now.
    Can anyone please tell me if I can overcome this problem?
    Thanks,
  2. Richard_R
    5,690
    4,390
    I think on the X-T2 you have the ability to decide which items appear on the Q menu. Maybe if you go into the camera menu system you will be able to resolve the issue by changing what appears.
  3. Jack Crouch
    Apr 21, 2017
    HI richard,
    Thanks for posting the solution! I had read online before I bought the X-T2 how difficult the menus could be but didn't realise just how much. I have recently changed from a Nikon system where I found the menus quite easy to follow.
    It has made me read the manual more than I normally would so there is something positive there.
    Thanks again.
    Jack
  4. Jbat
    Jbat Well-Known Member
    May 13, 2016
    161
    49
    Charleston, SC
    Its on page 247 in my manual. How to change Q menu settings. You can easily change any of these buttons to be any of the other settings that you want it to be.
    Joel
  5. Jack Crouch
    Apr 21, 2017
    Thanks Joel - very helpful
