X100 w/ Ricoh TC-1 (1.88x)
Discussion in 'Fuji X Accessories' started by gleeman, Mar 2, 2012.
  1. gleeman
    gleeman Member
    Apr 27, 2011
    92
    52-49 + 49-52 + 52-43
    very slight vignette when the lens is focused on a near distance object
    PROS
    lightweight
    low distortion, low CA
    CONS
    bigger vignette(when focusing at far distance)
    AF hit or miss
  2. videogamemaker
    videogamemaker Member
    Feb 24, 2011
    1,132
    109
    Iceland
    Thanks for the examples. Your filter adapters look like they push the adapter quite far from the lens. Maybe try using slimmer ones or a single adapter if possible?
  3. gleeman
    gleeman Member
    Apr 27, 2011
    92
    this is the best setup I've tried so far
    I also tried 49mm adapter + 49-43 step down ring, the lens will hit the 49-43 ring if You try to focus
  4. gleeman
    gleeman Member
    Apr 27, 2011
    92
    more photos
  5. Frankie
    Frankie Premium Member
    Mar 31, 2011
    3,108
    451
    The Left Coast
    I am interested in this tele-adapter.
    What is the mounting thread size? Studying your pictures, I presume it is f-52mm???
    If so, there is an adapter ring that changes the Fuji f-49mm into a f-52mm and may provide the closest fitting...which should also clear the X-100 lens at macro mode. See: http://www.ebay.ca/itm/JJC-CAMERA-LENS-RING-ADAPTER-FUJI-X100-52mm-FUJIFILM-/220843272300?pt=LH_DefaultDomain_0&hash=item336b48e86c
  6. gleeman
    gleeman Member
    Apr 27, 2011
    92
    Hi Frankie
    it's 43mm thread
    as you see, I tried a 49-43mm step down ring first, the lens will hit it
    current Setup :52-49(as a short 49mm adapter) + 49-52 + 52-43
    (52-49 as a short 49mm adapter)
    (49-52 + 52-43)
  7. Frankie
    Mar 31, 2011
    3,108
    451
    The Left Coast
    So, what is needed is a thread-size build up from f-43mm to f-49mm...I have used such devices before, might even have one in-stock...stay tuned.
    See: http://www.ebay.ca/itm/49mm-43mm-49-43mm-49-43-Step-Down-Ring-Adapter-/320745789540?pt=US_Filter_Rings_Holders&hash=item4aadf05864
    To avoid the X-100 lens hitting something, an 8mm allowance from the back flange [after screwing off the cover-ring] is needed. Fuji, UN and many others have a total ring depth of 9.2mm [allowing for also a filter]
    I will try also to find a f-49mm to f-43mm adapter of 8mm+ depth...that way, the Ricoh unit and be mounted directly onto the f-49mm Fuji lens thread.
  8. gleeman
    gleeman Member
    Apr 27, 2011
    92
    Frankie,
    I have one
    the fuji lens will hit the 49-43 ring, not the back flange of teleconverter
    49-43
    52-43
  9. Frankie
    Mar 31, 2011
    3,108
    451
    The Left Coast
    Ah...now I understand.
    The X-100 lens unit dia. is ~45mm...will hit any smaller opening if not enough depth is allowed.
    So, the thread-reducer needs to be nearly flat...at least not pround of the Ricoh thread itself. What...~2.5mm???
    What is needed is a one-piece f-49mm to f-43mm adapter with a cavity depth of 8mm+...similar to this DIY hood idea except the threaded opening is 43mm. [The ID of that m-49mm~f-43mm donor part is 46mm and clears the X-100 lens unit.]
    I have studied your set-up in Post 1. Also, the Ricoh lens quality is the best I have seen...if the vignetting could indeed be reduced to the minimum by mounting the unit closest to the X-100 lens.
    I would be happy even if the set-up only works in non-macro mode. In such case, the depth needed is only 4mm total [The X-100 lens at "off" protrudes 0.6mm beyond the lens collar; recesses ~1mm at infinity and flush at 0.5m focal distances]. My avatar DIY dome hood is based on those measurements.
  10. gleeman
    gleeman Member
    Apr 27, 2011
    92
    Hello Frankie
    maybe you can make a adjustable adapter ... :rolleyes:
    also I think that we'll be happy with this teleconverter if the X100 has in-camera digital zoom/crop to about 50mm lens FL ....
  11. gleeman
    gleeman Member
    Apr 27, 2011
    92
    1.this is AF-without-macro setup (also focus distance must be far than 2M to avoid hitting the lens)
    52-49(52mm male thread) + 58-52(52mm female thread inside) +52-43(52mm male thread)
    2.compare to AF-with-macro setup(52-49 + 49-52 + 52-43)
    3.MF and handheld the teleconverter,that's the limit I can reach
  12. Frankie
    Mar 31, 2011
    3,108
    451
    The Left Coast
    This is what I have in mind:
    The f-49mm silver adapter ring is wide enough and depth good enough for maximum macro...as is in the set-up pictured. All I have to do is replacing the original f-30.5mm adapter pictured [minimum ID 46mm] with a f-43mm one [minimum ID 46mm if available or lathe to fit]...the Ricoh TC-1 screws right in.
    Counting threads in your pictures, the TC-1 would need 3 x 0.75mm+ in total thread depth, plus something... What is the total depth from flange???
    In making a thin MF non-macro unit, internal depth for the lens needs only be 4mm [same as my DIY hood], reducing the distance resulting in a little vignetting at f-11, very much like your hand-held shot.
    [The X-100 lens at "off" protrudes 0.6mm beyond the lens collar; recesses ~1mm at infinity and flush at 0.5m focal distances...tried-and-true].
    I would probably make it in two pieces, with the silver adapter ring only deep enough so that after unscrewing the TC-1/adaptor-top as one unit would leave enough thread [3 x 0.75mm] in the silver ring as a simple f-49mm thread adapter for dome hood and filters.
    Post-processing cropping of residual vignetting is easy enough.
  13. gleeman
    gleeman Member
    Apr 27, 2011
    92
  14. jknights
    11,995
    2,362
    These results are similar to when I tried a x3 teleconverter.
    My x2 unit also vignettes very slightly from f4/5.6 upwards.
    The same is true with the x2.2 but it starts to vignette at f2.8
    I'm sure that somewhere there is a solution but I just need to find a good camera shop with a lot of different sized teleconverters.
  15. gleeman
    gleeman Member
    Apr 27, 2011
    92
    Vignette is not a big deal
    I've tried some TCs,
    This TC is the only one delivered low CA and low distortion.so far
    F8 ,JPEG ,cropped
  16. gleeman
    gleeman Member
    Apr 27, 2011
    92
  17. Frankie
    Mar 31, 2011
    3,108
    451
    The Left Coast
    The last example in Post 11, if cropped ~10% would be clean enough. That would essentially be a digital zoom making it a 2X extender equivalent...I would be happy with that.
    Such custom flush-mounting would allow an infinity to 0.5m focal range and I am happy with that as well...shopping time.
  18. videogamemaker
    Feb 24, 2011
    1,132
    109
    Iceland
    How wide is the back glass opening? like the physical width of the glass closest to the fuji lens? This looks like a nice converter, but at 150 USD it's one of the more expensive ones.
  19. matzan481
    matzan481 New Member
    May 31, 2011
    Why is it so magenta colored?
