10-24 Cleaning
Discussion in 'Native X-Mount Lens Forum' started by Jimbofoxman, Jul 17, 2017.
  1. Jimbofoxman
    Jimbofoxman Well-Known Member
    May 17, 2014
    38
    57
    Michigan
    Wow, they really get you on a cleaning! $167 seems a little steep to me. Canon Pro was so much better. Still love my Fuji stuff though.....but maybe they should build a tighter lens. Had dust on the inside of both the front and rear elements.
  2. monst
    monst Premium Member
    Nov 27, 2013
    223
    56
    Wow that is a lot. Did it show on the pictures?
  3. Jimbofoxman
    May 17, 2014
    38
    57
    Michigan
    Yes, you could see it in several locations on a picture. Most times I could clean it up with just a simple spot heal. Sad to spend all that money on a lens and so easily get stuff inside.
  4. ojporqpojrewpo
    1,067
    406
    The 10-24 definitely should be WR. Seems this kind of lens is used outdoors a lot.
  5. archi*dss
    archi*dss Premium Member
    Aug 9, 2011
    641
    151
    netherlands
    The price for taking apart and reassembling such a complicated zoom lens doesn't surprise me. Although zooming is internal, the lens groups moving may be pumping air into the lens along with dust. Mine is still clean but it hasn't seen much use yet. Since this one zooms internally it could easily have been made WR and sealed.
  6. Bud James
    Bud James Premium Member
    758
    366
    SE PA
    I use my 10-24 a lot for travel photography. It's a great lens, very sharp and has the focal length range needed to shoot interiors and exteriors of churches and other building in old cities.
    In March, I spent a week in Iceland. I photographed the iconic waterfalls and other landscapes. I was almost under one waterfall with my X-T2 and 10-24 on a tripod with Lee Big Stopper ND filter take photos. By the time I was done, the mist from the waterfall had soaked me and my equipment. I had a rain jacket on, but my equipment did not. It seems that my 10-24 came through that without any ill effects.
    You can check one of the waterfall images by clicking Please login or register to view links.
    If Fuji introduced a "Mark II" version of this lens with weather resistance, I would buy it without hesitating.
    Regards,
    Bud James
  7. monst
    Nov 27, 2013
    223
    56
    Zooms have always been prone to the dust sucking phenomenon. The press guys used to put a bit of double sided tape in the inner of the rear lens cap to try to trap the particles but was never sure about if that worked.
