18-55mm issue...
Discussion in 'Native X-Mount Lens Forum' started by Jchow, Jan 13, 2018.
  1. Jchow
    Jchow New Member
    Jan 13, 2018
    Hi,
    I am currently having an issue with the 18-55mm, I think I have caused the lens to decenter due to impact. The lens has no physical damage from what I could see. I have confirmed that the contact pins on my XT-2 body have not been damaged since my 35mm works perfectly fine.
    My 18-55mm is causing a lens control error every time OIS is turned on. When turned off, shooting at narrow apertures, it gives a very strange ghosting effect.
    I would really appreciate it if someone could tell me what the problem is before I send this to Fuji for repairs.
    Thanks!
  2. Marty M
    Marty M Premium Member
    Jun 22, 2014
    598
    372
    42301
    People can only speculate as to what the problem may be. Your quickest resolve will be to send it in.
  3. marsmail
    marsmail Premium Member
    Jul 18, 2013
    602
    118
    GB
    As Marty said, we can only speculate, but the fact that the main problem occurs when OIS is on really suggests that the "floating" element which does the stabilising has somehow got out of alignment due to the impact. The odd ghosting would be a likely result of such misalignment too.
    Only real answer is to senf it in and hope it is not too expensive to repair.
    marsmail
