Any Takumar owners out there?
Discussion in 'Adapted Lens Forum' started by sceptic, Mar 21, 2013.
  1. MercedesMorgan
    MercedesMorgan Member
    Jun 30, 2017
    Yeah!, right?!!! Serves me right for not looking at the lens more closely. Still on the hunt for something closer to 50mm equivalent.
  2. johant
    johant Premium Member
    Apr 25, 2015
    1,788
    811
    Netherlands
    Well, consider yourself lucky nevertheless; you got one of the finest Takumar lenses, in my opinion.
  3. MercedesMorgan
    Jun 30, 2017
    It's not at all bad.
  4. palane
    palane Member
    Dec 23, 2016
    45
    Consider the M series Pentax K mounts,you will need the adapter of course.
    When the K mount was introduced Takumars ended.The first K series wasn't marked(K) but the next series M was marked.They are the cheapest of the Pentax series.35mmF2.8 is usually a bargain.
  5. MercedesMorgan
    Jun 30, 2017
    Thanks for that!
  6. Alex Cremers
    Alex Cremers Premium Member
    620
    515
    Antwerp
    Get one of these and attach your 55mm 1.8 to it!
    Please login to view links
  7. MercedesMorgan
    Jun 30, 2017
    Do you have one? Does it affect the colors or quality of the lens?
  8. Alex Cremers
    620
    515
    Antwerp
    I have the Lens Turbo II and I would gladly buy a new one if something were to happen to it. As far as I can tell, it doesn't change the character of the lens. Some say it makes the lenses seem sharper.
  9. MercedesMorgan
    Jun 30, 2017
    Good to know! Seems that there are some bad reviews about this damaging the sensor, though. Sounds like you haven't got that problem!
    Alex Cremers likes this.
  10. palane
    palane Member
    Dec 23, 2016
    45
    The 50mm f1.4 doesn't fit a speedB/FocalR(but fits all my other Taks so far.)....Like having another set of lenses.
  11. Alex Cremers
    620
    515
    Antwerp
    It almost doubles it! I think the later Pentax 50mm 1.4 doesn't have that problem, but yes, the lenses of which the rear element is sticking out too much are a problem, not only with a focal reducer but also with DSLR cameras where the rear element will hit the mirror. The Takumar 55mm 1.8 is safe, so is anything longer than 55mm by Takumar.
  12. Alex Cremers
    620
    515
    Antwerp
    I don't see how that is possible. The Lens Turbo II does not touch the sensor in any way.
  13. Mischa
    Mischa Vintage lover
    Oct 26, 2013
    2,903
    1,100
    Switzerland
    I think he was referring to the lens damaging the lens turbo, because the rear element (the metal thing above the glass) may collide with the front glass of the LTII.
    As of now, I'm not a Tak owner anymore. Sold mine at a way too low price but only one person placed a bid on my auction..
    goodbye, radioactive man
  14. Alex Cremers
    620
    515
    Antwerp
    I've a Super Takumar 50mm 1.4 and have gently hit the lens of the Lens Turbo several times. No problem! It just 'patting' the lens straight on, there's no rubbing (and thus scratching) between two elements. Of course, I was aware of the problem and didn't use much force.
    Same thing with the 28mm Takumars. The Auto Revuenon (or Auto-Rikenon) 55mm 1.4 also has this problem (of rear elements sticking out too much)
  15. MercedesMorgan
    Jun 30, 2017
    Here's a link to the reviews on that focal reducer on Amazon:
    The two bad reviews are here:
    When mounting on X-Pro2, it was not easy to screw it in. Once fully mounted and unmounted from the body, I found t left ugly marks on the upper plastic part over the sensor. I don't it is a problem of QC, but this product makes me quite annoyed.
    The rear element extends too far into the body of the camera. It gouged the sensor mounts and permanently damaged my X-T1 and X-T10. The same has been reported online by many other users. Using it risks damaging your sensor and voiding your warranty. DO NOT BUY.
    User error?
  16. Mischa
    Oct 26, 2013
    2,903
    1,100
    Switzerland
    Do you have yellowing in your Auto-Rikenon 55mm f/1.4?
    I just recently measured mine with a Geiger counter and the radioactivity was quite impressive :D
    I didn't take precise measurements, so can't compare with my Fujinon, Pancolar and Takumar, but I'd say it's pretty close.
  17. MercedesMorgan
    Jun 30, 2017
    Yes. No counter though.
  18. Mischa
    Oct 26, 2013
    2,903
    1,100
    Switzerland
    if the glass has a yellow tint (when you look through the lens at a white wall) then you can be fairly certain that it's a radioactive lens.
    If you're interested in these things, take a look at my blog posts regarding colour casts, radioactive lenses, etc.
    My Rikenon was heavily tinted and cleaned up pretty nicely under the Jangsjƶ lamp. Transmission got way better too.
    Haven't used it for photography in some time, since I had it at school to demonstrate radioactivity in everyday objects. :D
  19. Alex Cremers
    620
    515
    Antwerp
    I use it on a X-T1 and I don't have that problem. Listen to the positive reviews!
    MercedesMorgan likes this.
  20. Snodge
    Snodge New Member
    Sunday
    Bristol, UK
    I have the Super-Multi-Coated Takumar 50mm f/1.4 - in silver (mmm, shiny!) and it is a great lens, but as others have noted, I can't use it with my Lens Turbo II. It does seem to take images with a slight yellow cast though.
