Card read errors X T1 and X Pro1
Discussion in 'X-T3, X-T2, X-T1, X-T20, X-T10, X-T100' started by Koban, Mar 19, 2014.
  1. Tailwagger
    Tailwagger Premium Member
    Dec 21, 2012
    706
    277
    Boston, MA
    At the moment, we dont know which device to blame, the card or the camera. If it works with a different card then we know something is wrong with the card... if not, and you've properly formatted everything etc, then perhaps the camera has a problem.
    A couple of questions since you dont have a second card. First, if you format the card, shoot photos and then try to review your shot do you see the error? Or is it only after you pull the card and try to read it onto the mac and then re-insert it into the camera? If its the latter, how are you reading the files into the computer? If your using Preview, that is the source of your problem. Copy the files in first eject the card and then run Preview. Preview puts some hidden files (files that you cant normally see and are named with a . as the first character). The Fuji software screws up if it encounters hidden files it doesnt expect. If your not using Preview to read in the files, what are you using?
    Frued likes this.
  2. Frued
    Frued New Member
    May 28, 2014
    18
    Rocky Mountains
    Me using Preview directly on the card on my Mac. I already had formatted the card in the camera and all that. What you are saying makes sense, its the Mac that is putting some secret files onto the SD card, then the X-t1 gets paranoid seeing them. Is Fuji listening to this issue?
  3. Frued
    Frued New Member
    May 28, 2014
    18
    Rocky Mountains
    Thank you for your detailed help.
    Kind regards,
    F
  4. snaphappy
    snaphappy Member
    Apr 5, 2014
    95
    Davao Philippines
    I use asepsis too and it works for me. Apart from importing the images into LR I avoid messing with the SD card.
  5. Tailwagger
    Dec 21, 2012
    706
    277
    Boston, MA
    Yep thats your problem. Preview seems to insist on putting some hidden files into the directory, I'd assume to help it render or index the content in some way. The Fuji software doesnt expect to see these files and gets confused when it encounters them. Assuming you dont have Lightroom or something similar, the solution is to always import the files onto the Mac via finder and properly eject the card. I use LR, so I dont know if iPhoto causes a similar problem.
    This thread has been around for a while... it is rather surprising that this bug still exists, but I dont think we can say one way or the other if they'll fix it or not at some point. They might feel, though personally I'd disagree, that this is a preview bug and not something they need to fix.
  6. kitzhubsch
    kitzhubsch Member
    Jun 29, 2015
    60
    Prov. Antwerpen
    Maybe removing sd card from spotlight aware folders would do some help? As much as I understand you guys have issue with indexing data that Apple's OS creates on media. This is completely useless since data on SD card is constantly changing and indexing does nothing useful. Check in perferences>spotlight if there is sd card link and uncheck if exist.
    I also use OSX and never ran on this kind of issue.
    Sent from my iPhone using Tapatalk
  7. Chema Hdez
    Chema Hdez New Member
    Apr 28, 2014
    Tenerife, Spain
    well... I friend of mine has the same problem... and the problem was that she uses a MicroSD card with an adapter.... without the microSD card.... the camera thinks that a card is inside, and try to write... on nothing.... when the "Card" (really the adapter) goes to the Mac, the mac shows a problem reading the card... because no card is inside the adapter.... but the SandDisk Extreme that you use isn't a card adapter... ;) try with another card. Maybe the card is broke.
  8. Frued
    Frued New Member
    May 28, 2014
    18
    Rocky Mountains
    I checked, it wasnt there.
    I am using a normal SD card full physical size.
  9. eurotrash
    eurotrash Premium Member
    Mar 19, 2014
    816
    124
    DC, USA
    We pretty much all agree that it's an issue with A: MacOS and B: files being written to the card by said OS. Another card, different and known working sample and no computer involvement would be the first thing I try. If issue persists, one can deduce the camera is to blame and a call to Fuji would be my next step. If the issue is not replicated when no computer interaction is present, then the OS is causing the issue upon insertion. Where you go from there is the question. My issue seems to have resolved itself after a few formats in camera and has not popped up more than a scant number of times in quite awhile. Usually, tuning off the camera and turning it back on again mitigates the issue for whatever reason.
  10. eurotrash
    Mar 19, 2014
    816
    124
    DC, USA
    Do you have a machine running windows? Might be worth a shot to test that too while your at it to see if the issue remains after unerring into that machine. If yes, problem with card is almost 100%. Troubleshoot it as far as you can though, rule out things and the culprit may be something unexpected. Of course it could just be MacOS being ridiculous.
