Fine-Tune White Balance?
Discussion in 'X-T3, X-T2, X-T1, X-T20, X-T10, X-T100' started by Bruce K, Dec 7, 2017.
  1. Bruce K
    Bruce K Member
    Apr 3, 2017
    49
    Edina, MN
    I've set my white balance to 4500k and I've made some fine-tune adjustments of R and B. I am curious how I could make a green adjustment if that is possible? Please note I am color blind so I have to do this mechanically. Screen Shot 2017-12-07 at 9.41.13 AM.png
  2. monst
    monst Premium Member
    Nov 27, 2013
    228
    60
    red is the opposite of green so changing that will change the green
  3. Bruce K
    Bruce K Member
    Apr 3, 2017
    49
    Edina, MN
    So does reducing the red increase the green?
  4. ysarex
    ysarex Premium Member
    1,085
    740
    St. Louis
    Yes.
  5. Bruce K
    Bruce K Member
    Apr 3, 2017
    49
    Edina, MN
    Thanks for the help.
  6. PatrickP
    PatrickP Premium Member
    Nov 30, 2014
    667
    311
    Netherlands
    I'm wondering why you want to do that. Even more if you say you are color blind. These kind of changes do more harm than good if you change it for all photos you take...
  7. Bruce K
    Bruce K Member
    Apr 3, 2017
    49
    Edina, MN
    I'm setting up to shoot in my shop/studio which has all 5000k LED lights, and I have many windows. Auto white balance is good, but it shifts throughout the day as the sunlight changes, and it changes based on subject matter. I need a consistent white balance so I don't need to rely on my eyes since I am color blind (red/green). My wife has been helping me confirm the colors in my photos. So far using a white balance K setting with some R and B adjustments is working good and it is consistent.
  8. leoda1945
    leoda1945 Premium Member
    Apr 30, 2013
    1,688
    1,986
    People's Rep. of Mass.
    If the light is changing through the day wouldn't manual white balancing each shot be a good solution ?
    EDIT: I don't mean changing color temperature, I mean using a white card, manually.
  9. Bruce K
    Bruce K Member
    Apr 3, 2017
    49
    Edina, MN
    I do understand what you are saying, and I have tried that. My studio photos lights and my overhead lights are all 5000k. They blow out most of the sunlight effects. It seems like of all the settings I have tried this white balance K setting works the best for me in this situation.
  10. magmouse
    magmouse Premium Member
    Jul 19, 2015
    853
    1,417
    London, UK
    No. The opposite of green is magenta, which in the RGB system is a mix of red and blue. So to add green, you need to remove equal amounts of red and blue. This means moving the control point down and to the left in the colour balance control widget. Similarly, to reduce green, add equal amounts of red and blue.
    spudl and pfogle like this.
  11. leoda1945
    Apr 30, 2013
    1,688
    1,986
    I think I see ..... You mean that the auto WB (internal camera setting) changes when the colors of the objects you are photographing change.
    You don't mean that the window light changes (because your studio lights dominate).
    Side note: I am not positive that setting K temperature will yield a perfectly consistent white card color (white!) if you change a lot of the other colors in the frame. I am thinking that it may just be scaling its Auto WB calculation. Which would be just as inconsistent as setting Auto WB. I don't know one way or the other, but I would check that out if colors are very important. (I promise myself to look at this at some point.)
  12. spudl
    spudl Premium Member
    Nov 25, 2014
    235
    209
    I'm over here!
    I find a solid knowledge of the colour wheel is a good starting point for adjusting colour balance.
  13. AdrianG
    AdrianG Premium Member
    Feb 22, 2016
    1,770
    1,464
    CH, UK, GHA
    If his lights are consistent, WB will be consistent, regardless of subject colour. If he adjusts the hue it will likewise be consistent for all his shots, regardless of subject colour.
  14. Bruce K
    Bruce K Member
    Apr 3, 2017
    49
    Edina, MN
    I shot many pictures in my shop/studio throughout the day with varying amounts of ambient sunlight and I had my wife review them for color accuracy. It seems I have the K setting with the minor R and B fine tuning correct. Using one setting will save me a lot of time while shooting and in post.
    I also had her tell me the colors on the R B grid on the camera screen, and now I can tell which way to move to make the minor adjustments. I did find that it was a combination of first finding the correct K value, then fine tuning from there. It was a good exercise.
  15. Bruce K
    Bruce K Member
    Apr 3, 2017
    49
    Edina, MN
    And that is exactly what I need. Thanks
  16. leoda1945
    Apr 30, 2013
    1,688
    1,986
    I've decided that I don't really inderstand the problem, so it's safe to ignore whatever I posted above.
    :p
  17. Bruce K
    Bruce K Member
    Apr 3, 2017
    49
    Edina, MN
    Leoda1945, like I said; "I am color blind so I have to do this mechanically." Your comments were helpful.
    leoda1945 likes this.
