Help!! How to create such unique color tone
Discussion in 'Post Processing/Software Forum' started by Photofaces, Apr 25, 2018.
  1. Photofaces
    Photofaces New Member
    Apr 25, 2018
    Hi Guys,
    I came across these images and it was taken with X100s. The color tone is very unique. Anyone knows how to re-create them either in camera or psot editing.
    Thanks and appreciate
  2. Robmas4229
    Robmas4229 Premium Member
    Mar 13, 2015
    1,120
    748
    Florida, USA
    They look like HDR. To me.
    leoda1945 likes this.
  3. GDRoth
    GDRoth Premium Member
    Dec 27, 2011
    1,651
    578
    Southeast Michigan, USA
    Yes, I'd guess HDR with a unique recipe of processing. You'll probably just have to use trial and error to find the combination you like best.
  4. MikeHuff
    MikeHuff Premium Member
    Oct 18, 2013
    108
    101
    California
    Don't know how it's done, and personally it's not a look I care for.
    However, if those were my watermarked images I'd not be happy with you taking them and posting them somewhere else. Best practice might be to post a link for people to see. Only exception might be if these images were posted and clearly designated as available to anyone unrestricted. Seeing a watermark on them would suggest that is not the case.
  5. Westmill
    Westmill Premium Member
    Nov 15, 2012
    1,791
    801
    Stoke on Trent
    Looks to me like they were tone mapped in photomatics !
    The obvious thing would be to ask the photographer.
    Who may or may not like to share his style with others :)
    lawsofphysics likes this.
  6. FredGUnn
    FredGUnn Premium Member
    Aug 9, 2015
    291
    188
    Not my cup of tea either, but you can fake it in Lightroom (you didn't say what you use for PP) by cranking up the Shadows, dropping the Highlights, and cranking up the Clarity. Then use the Saturation slider to quickly get the color you are going for, but with the muted reds in the 2nd and 3rd, starting with Classic Chrome might be enough.
    JimFenner likes this.
  7. ru2far2c
    ru2far2c Premium Member
    Mar 13, 2014
    301
    189
    Cuenca, Ecuador
    Experiment..... in Light Room, Adobe ACR, Photoshop, C1
    Look into Photomatix or Aurora. Google - tone mapping.
    +1 what Mike Huff said.....
  8. Fujiphotog
    1,953
    2,017
    Some of them appear to have wide vignetting applied, or gradient filters with darkening.
    Sean73 likes this.
  9. Richard_R
    8,411
    9,254
    Agree. At the very least the OP should be posting a link to where the originals of the images are located.
  10. F2Bthere
    3,411
    1,923
    The post processing advice is good.
    There are many ways to post process an image for a given result. The basic gist is that you want to pump up midtone contrast. Many ways of getting at this will also bump up the saturation.
    These images also appear to have a solid dose of color grading and it looks like brightness levels were used to manipulate where colors were applied. I would approach this part with channel masks, blend-if sliders for layers or luminosity masks, because these methods give more precise control. The actual color changes can be done with curves, solid color layers, LUTs, etc. Color toning, perhaps combined with white balance manipulation, might work, but lacks finess and control.
    The effect could be boiled down to a LUT, although it would probably require some tweaks to get it perfect. Most well-done grading and contrast manipulation requires at least final adjustment to suit the image.
    But just getting at the tools is only a piece of the battle. The big issue is being able to visualize what you want and to see the adjustments which move you to your goal.
    The other issue not covered is the lighting conditions in which these images were created. The original exposure is important for best results.
    The actual tools used, only the person who did the post processing knows. But a huge number of ways you can get there have been listed.
    Personally, I would use a combination of the methods in PS, whichever seemed to get me there the most aesthetically (adjustments always risk some image degradation), but it is probably possible to do it all with curves adjustment layers combined with basic layers tools (blend modes, masks, etc).
    Capture One also has the needed tools and the latest version would make it much easier since the layers have become so sophisticated, especially when combined with the advanced color tools.
    I could see getting there with LR, but it isn't the tool I would choose.
    In short, pick a tool, look closely at the images themselves, create an image with similar lighting characteristics and roll up your sleeves :).
  11. Benjamin Kanarek
    Benjamin Kanarek Premium Member
    Oct 8, 2017
    156
    215
    Born in Toronto, Canada based in Paris, France
  12. ru2far2c
    Mar 13, 2014
    301
    189
    Cuenca, Ecuador
    Good advice.....
    Stewpot likes this.
  13. (c)ow
    (c)ow Premium Member
    Apr 19, 2013
    1,482
    1,004
    Stuttgart, Germany
  14. lawsofphysics
    lawsofphysics Premium Member
    Apr 17, 2013
    2,647
    1,050
    If one can tell it was tone-mapped, there's too much tome mapping.
    An important exception involves viewers who enjoy the tone-mapped aesthetic. Then there is no such thing as too much tone mapping.
  15. F2Bthere
    3,411
    1,923
    Have you used this program?
    It looks pretty expensive for the limited functionality. It also seems that it won't be able to make very sophisticated LUTs, since it only has the outcome image. At best the results will be two dimensional. The skin protection, if well implemented, is a wise feature to add. I'm basing this on my understanding of how images work, not on direct experience.
    I have the Retouching Toolkit, which is a much more versatile tool I find myself using with almost every image which goes through PS. It has a couple features which I think will do what the image 2 LUT program does with more control for the user: Gradient Map Maker and Gradient Map Picker. Once you have a map, PS can easily export it as a LUT.
    To be clear, I have not used image 2 LUT and would love to hear feedback from someone who has.
  16. (c)ow
    Apr 19, 2013
    1,482
    1,004
    Stuttgart, Germany
    Have the demo installed and played a little with it. I'm no expert on LUTs but it seems OK for starters. You can export a 3D LUT(3dl, cube 17, cube 32, mga), based on the target image preview (which you can tweak with the sliders and setting). Their videos explain the functions well.
    The created LUT can be imported into Camera Raw and is afterwards available in LR also.
    F2Bthere likes this.
  17. F2Bthere
    3,411
    1,923
    Is the demo a limited time demo or a limited capability demo?
    EDIT: Never mind :). I see from the site it's 14 days. Looks like I need to pick a window where I will have enough time to evaluate it.
  18. (c)ow
    Apr 19, 2013
    1,482
    1,004
    Stuttgart, Germany
    Full functional but you can export 3 or 5 LUTs only.
  19. F2Bthere
    3,411
    1,923
    Looks like @(c)ow is on the cutting edge. Although the company has been around for some years, it appears this software just came out a few weeks ago!
    I'm going to give it a try...
  20. (c)ow
    Apr 19, 2013
    1,482
    1,004
    Stuttgart, Germany
    Not so difficult ;) I browse fstoppers on a regular basis. There I stumbled over it:
