How to Set Up a Fuji X-T20 to Use a 3rd Party Flash
Discussion in 'Fuji X Flash and Artificial Lighting (LED, etc.)' started by Dave Jenkins, Sep 13, 2017.
  1. Dave Jenkins
    Dave Jenkins New Member
    Aug 16, 2017
    The Beautiful Northwest Georgia Mountains
    To use a 3rd party flash on a Fuji X-T20, go to the menu for "Flash Setting." Choose "Flash Function Setting" and press the right selector button on the back of the camera. This brings up a screen called "Sync Terminal." In the upper left is a box that says either "Off" or "M." If it's "Off," turn the Rear Command Dial to bring up "M." This will also open a small panel called "Sync" in the lower right of the screen. Navigate to it via the selector buttons, then use the Rear Command Dial to choose front or rear curtain sync. Press the "Back" button to exit.
