Mission Improbable
Discussion in 'Adapted Lens Forum' started by jamie allan, Aug 5, 2017.
  1. jamie allan
    jamie allan Premium Member
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    I've got more than enough 50mm-ish adapted lenses but have always wanted to get a Konica 50mm f1.7. Since I'm retired now I've time to take on a project and this is it.
    It's got a damaged filter ring, missing focus rubber and fungus on the glass but according to the seller the aperture blades are functioning correctly and the focus is smooth. I've dismantled Konica AR lenses before (but never the 50mm) to clean them and convert them to 4/3 mount. I'm looking forward to the challenge of getting this working again as it's reputedly extremely sharp when functioning correctly.
    Gyles likes this.
  2. ScottyMac
    ScottyMac Well-Known Member
    Mar 6, 2017
    80
    52
    Colorado
    You must have steady hands and good eyes. Moving into retirement myself...but I don't think I possess your skills. Let us know how that goes.
  3. Gyles
    Gyles Member
    Aug 25, 2016
    48
    Norfolk, UK.
    Great project. Just this minute posted a picture taken with the Hex 50/1.7. Well worth the effort.
    Please login to view links
    jamie allan likes this.
  4. leoda1945
    leoda1945 Premium Member
    Apr 30, 2013
    996
    786
    People's Rep. of Mass.
    If possible ....... document the disassembly, cleaning and reassembly process. Hints (like marking things upon disassembly) are important too.
    I disassemble a Hex 40mm and it's still in pieces !!!
    :eek:
    The world needs good instructions :D
  5. jamie allan
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    I've taken apart and re-assembled a Hexanon 28,35 and 40 when I modified them for 4/3s use a number of years ago. That actually entailed the use of a dremmel:eek:.
    There's a few sites I've come across to assist with this particular lens. I've already made a softwood former and hardwood punch and I've plans to use a shoe stretcher if that fails.:eek:
    I'm stumped at present for a focus ring rubber however.
  6. Greg_E
    Greg_E Premium Member
    Jul 7, 2012
    2,251
    263
    how about here? Please login to view links
    I know the US site has rubber cones that will do what you need, if you can get the ring round enough to work again.
  7. jamie allan
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    Thanks Greg but the rubber I'm talking about is the rubber covering the focus ring on the lens.
    I've already got a home made tool to get the front ring off.:)
    Gyles likes this.
  8. Gyles
    Gyles Member
    Aug 25, 2016
    48
    Norfolk, UK.
    :)looks like you're building yourself a periscope there
  9. Greg_E
    Jul 7, 2012
    2,251
    263
    I usually carefully sneak a small screwdriver under that rubber and roll it all the way around to break the glue. The struggle to slide it off the ring, having the screwdriver in to help it jump the ridge in the ring can help. You can often get a small section displaced, roll the screwdriver and push a new section down, eventually once the entire edge is over the ridge, it should slide off with some force.
  10. lifesshort
    lifesshort New Member
    Jun 22, 2017
    If nothing else, you could try using a piece of bicycle tire inner tube as the focus ring rubber.
  11. Frankie
    Frankie Premium Member
    Mar 31, 2011
    3,212
    488
    The Left Coast
    @jamie allan...There is a tool for bending filter mount...see: Please login to view links
    You could file down the convex side of the form to fit the lens.
  12. jamie allan
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    Well my 50mm f1.7 arrived this morning. Here's a side view
    I spent a couple of hours on it - fixing the dent, stripping it down, cleaning and re-assembling it. Unfortunately the only guide I could find is for another version of the lens so wasn't that much use to me. I've a problem in that I cannot separate the 3 front elements as I cannot see how to break down the assembly. There's a small amount of fungus on the rear of the front element. I haven't painted it yet and haven't put the nameplate ring back on but it still functions well.
    Here's a couple of example shots with no cropping after cleaning.
    At close focus of 0.45m
    At infinity - the tower blocks are about 0.75km away
    Knapdale likes this.
  13. jamie allan
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    And a couple in the shade at wider aperture. Again no cropping has been done.
    lifesshort and JamesMc like this.
  14. Knapdale
    Knapdale Well-Known Member
    Aug 23, 2015
    97
    103
    Argyll, Scotland
    Interesting, Jamie.
    Have you tried unscrewing that ribbed flange around the front element? There's a hint on this discussion that it might be as simple as that:
    However, I read in another thread that the Konica parts were screwed together very tightly, possibly with thread-lock, which might need some solvent and elbow grease....
    Good luck with it! I'd be interested to see how you get on with it.
    Stan
    p.s. your photo's look great without any further fiddling - but I'd want to get at that fungus, too!
  15. jamie allan
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    Thanks Stan,
    It's a lovely lens I really like it.
    I've spent some time trying to get the front elements separated but can't see how they do come apart. The front elements are held together with a plastic surround. There appears to be two parts to this surround for the front elements and I've stripped the glue with solvent but cannot get them apart. The only issue with leaving the fungus that I think I can see is a lack of contrast in shots taken in bright sunshine.
  16. jamie allan
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    Stan,
    I took your advice and stripped the lens again and soaked the front element assembly in isopropyl alcohol. I could see that on opposite sides of the ribbed flange where it joined the other part there was a strip of glue locking the threads. I softened it and then used a sharp point to clear it. Applying a bit of elbow grease the two sections unscrewed. I was able to remove the front element and clean it in vinegar and then in isopropyl alcohol. It's revealed a couple of scratches on the front of the front element - I'd guess someone thought the fungus was on the outside.
    I put it back together and here's a quick shot on a dull day at closest focus of 0.45m and no cropping.
    JamesMc, lifesshort and Knapdale like this.
  17. Frankie
    Mar 31, 2011
    3,212
    488
    The Left Coast
    For that missing rubber ring, peruse...: Please login to view links
    Cheaper and funkier alternative...see: Please login to view links
  18. Knapdale
    Aug 23, 2015
    97
    103
    Argyll, Scotland
    Jamie - Magic, that looks great. Glad you got it sorted. Just enjoy it now - you've earned it!
  19. jamie allan
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    I really like the look of this lens in low light. It's a dull wet day here.
    leoda1945, charlie3, Knapdale and 2 others like this.
  20. jamie allan
    Aug 2, 2014
    1,322
    1,516
    Glasgow Scotland
    Here's a couple more from the now fungus free Hexanon 50/1.7. It's close focus ability is quite something.
    By the way this cost the price of a packet of cigarettes in th UK. I then pushed the boat out and added a screw on Hoya collapsible hood for £1.99.:D
    f8 1/250 iso400 - this is about 70% of the original image simply to take out stray branches and flowers.
    f8 1/180 iso800 - this is cropped to approx 10% of the original image just to show the detail you can get with this lens.
    JamesMc and leoda1945 like this.
