Pentax SMC Super Takumar 50mm f1.4
Discussion in 'Adapted Lens Forum' started by rybolt, Jun 18, 2017.
  1. rybolt
    rybolt rybolt Staff Member
    Aug 23, 2013
    2,495
    1,324
    Yellow Springs Ohio
    I picked up an ES camera with three lenses a few days ago. The lenses were 28mm f3.5, 50mm f1.4 and 200mm f4. I really had no interest in the 28 and 200 but I really wanted to try out the 50mm. It was not the thorium glass model which was a little disappointing but the lot of stuff also came with a set of Vivitar extension tubes which turned out to be great fun.
  2. adnan w
    adnan w Premium Member
    Aug 22, 2014
    352
    231
    seattle
    Every version of this lens is great.
    It's a classic.
  3. kevistopheles
    kevistopheles Analog
    Oct 21, 2014
    2,793
    3,198
    here
    That 28/3.5 is also a great lens
  4. rybolt
    Aug 23, 2013
    2,495
    1,324
    Yellow Springs Ohio
    I just shot a few with the 28. It works pretty well with the XT1. I'm going to thin out my stable of adapted lenses sometime soon and will need to take a closer look at that one. i think the 50mm f1.4 Super Takumar is going to replace 50mm f1.4 Pentax-M lens.
  5. Jim D
    Jim D Premium Member
    May 20, 2014
    314
    154
    Central America
    great color use in the subject separation , I have an 8 element version and like it very much .
  6. imagesfromobjects
    imagesfromobjects Remember
    Apr 29, 2015
    2,532
    1,861
    Philadelphia, PA
    I stumbled upon an early 8 element version, confirmed by serial number and protruding rear element, but without the yellowing by some miracle. Are you certain yours isn't radioactive? Pentaxforums has a couple threads and a serial database, so head over if you haven't already. How did you identify it? Just wondering...
  7. Alex Cremers
    Alex Cremers Premium Member
    710
    604
    Antwerp
    Love that shot!
  8. rybolt
    Aug 23, 2013
    2,495
    1,324
    Yellow Springs Ohio
    I was basing that on the fact that it didn't have the yellow coating. The serial number is 5668934. I looked at the Pentax Forum and it appears that it MIGHT be an eight element lens. I need to take a closer look at the back end. My initial reaction to the pictures is that it's very good.
    Thanks for the comments, everyone.
  9. Jim D
    May 20, 2014
    314
    154
    Central America
    It has been a while since I purchased it but I did use the info. from the Pentax forum to identify it , if I recall correctly it was something about the focus mark labeling . It is not as sharp as my fuji glass but when one takes into consideration it gets no help from the cameras processor it is quite good.
    Have only used it on the xe1 , need to try it on the xp1.
