Problem with aperture control Xe2s
Discussion in 'X-E1, X-E2, X-E2S and X-E3' started by Vinicius, Feb 14, 2018 at 12:03 AM.
  1. Vinicius
    Vinicius New Member
    Tuesday
    Hello!
    First of all I would like to apologize for my bad english.
    I put my hands on the xe2s and the 27mm xf lens today and i'm having a hard time controlling the aperture of the lens. To change the aperture i have to press the dial and scroll it, besides that it changes only one aperture size per time. Is there a way of changing the aperture by only scrolling the dial, without pressing it? It's very inconvinient pressing it every time i want to change the aperture.
    Thanks to everybody who answers!
  2. Vinicius
    Vinicius New Member
    Tuesday
    This lens doesn't have the aperture ring. So the only way of changing the aperture is through the dial
  3. fujixacros
    fujixacros Premium Member
    Jan 8, 2017
    488
    146
    Hello , and Welcome,
    You could use the camera body in Shutter Priority ?
    When the camera body is in Shutter priority , the aperture will be automatically adjusted according to speed and ISO.
    How to set the aperture to A , Auto.
    If you turn the control dial to the right past the F16 aperture setting, the Aperture setting will be A, Auto.
    The camera body will be in Shutter priority , or could be in [P] program mode if you already have set the shutter also to Auto
  4. fujixacros
    Jan 8, 2017
    488
    146
    Hope it helps.
    X-E2S owners Manual
    X-E2S Firmware Ver.1.10 (nov 21 2017)
    XF27mmF2.8 Firmware Ver.1.11 (oct 6 2016)
  5. Vinicius
    Vinicius New Member
    Tuesday
    I've set the command dial to chance aperture on the menu. But scroling It does nothing. i have to press It and then scroll. Is that normal? I would like to Just scrool It. Is there a way of doing that?
  6. Vinicius
    Vinicius New Member
    Tuesday
    Maybe its my camera's dial that is not working fine. I really don't know
  7. jamie allan
    jamie allan Premium Member
    Aug 2, 2014
    1,556
    2,046
    Glasgow Scotland Europe
    I don't have the X-E2s but do have the X-E2. I also have both XC lenses with no aperture ring. I don't have to press the command dial when rotating it to change aperture. Is it possible that a change in settings has caused this? Maybe try a reset of the camera.
  8. Vinicius
    Vinicius New Member
    Tuesday
    The reset didn't work. So it's a caracteristic of the xe2s or a problem with my camera's dial, witch I think it's more possible.
  9. Vinicius
    Vinicius New Member
    Tuesday
    Someone who has the xe2s and a xc lens could tell me If It works that way or If it's a malfuncition? Thanks to everyone who is trying to help!
  10. Vinicius
    Vinicius New Member
    Tuesday
    Someone could help me?
  11. jamie allan
    Aug 2, 2014
    1,556
    2,046
    As I said I don't have the X-E2s but do have the X-E2. I've looked at the X-E2s manual and it's references to the command dial are exactly the same as the X-E2. When I've checked my X-E2 with 16-50mm lens and press the command dial I get a magnified image of the scene I am pointing at. I can't see anywhere that a setting would cause this problem. I'd suggest you take it back to the store you bought it from.
    Vinicius likes this.
  12. beakhammer
    10,501
    6,735
    You should not have to press the dial. Using the dial on the upper right side of the camera-back, just scrolling it should work to change apertures.
  13. jdbish
    jdbish Premium Member
    Jul 13, 2011
    653
    84
    Katy, Texas
    I have the X-E2s and the 27mm lens and do not have to press the dial to change the aperture.
