Stuck Batteries
Discussion in 'General X Camera Forum' started by boulevardier, Mar 20, 2018.
  1. runswithsizzers
    Mar 17, 2017
    1,012
    1,477
    on the edge
    You say many third party batteries do not have the NTC resistor, which suggests some do. Can you point to a source which has published data about which third party batteries have the NTC resistor and which do not?
    Is there a simple test I can perform at home with a basic multi-meter to see if my batteries have the NTC resistor or not?
    As for the cost, how much more does the NTC resistor cost compared to a standard resistor?
  2. mfk
    mfk Well-Known Member
    Dec 17, 2014
    59
    65
    Switzerland
    I only had a Patona in my hands. The Patona has a 10 kOhm resistor at the place of the NTC. (The NTC may cost aprox. 20 cents more)
    "Some" is mainly based on the german-forum where this topic was discussed several times.
    With a Multimeter you may measure the resistance at 20-25°C, then heat the battery up by 10°C and check if the resistance is lower than 10 kOhm.
    Sorry, I'm at the moment in a Cahersiveen Ireland and can say nothing about the NTC coefficient.
    Regars, Ueli
