Suggestions for better monochrome
Discussion in 'X100F, X100T, X100S, X100, X70, XF10' started by kevistopheles, Jul 12, 2018.
  1. kevistopheles
    kevistopheles Premium Member
    Oct 21, 2014
    3,491
    4,836
    I've got a nice custom setting or two for color that I feel really works well but I am having a heck of time getting BW out of the X100 that I really like. I can make lovely BW using an app like Tonality or Silver Efex Pro but I'd like to get good BW without converting elsewhere (that's kinda the point really). I've gotten pretty close a few times but I'm still not quite there. I've tried the settings that worked well on my X-P1 and X10 and they're good but honestly worked better on the X-P1 and X10.
    What are some of your favorite custom settings for BW? Or some tips and tricks for getting the most out of your X100's for BW?
    Alfred Eyesenstadt and Bill W like this.
  2. kiwitracks
    kiwitracks Premium Member
    Sep 29, 2016
    320
    385
    Which model are you talking about? One of the newer ones with Acros or the original X100?
  3. LJClark
    LJClark Premium Member
    Nov 24, 2011
    512
    130
    Omaha, Nebraska USA
    I'm perfectly fine with Silver Efex Pro. If I'm going to be doing post processing a run through Silver Efex is no big deal. When all I shot was 35mm B&W I spent a heck of a lot more time per shot in the darkroom.
    Another thing to consider is that one B&W setting (or film) doesn't fit all situations. My degree was in photojournalism and we had a large number of photographers shooting a lot of different film -- I was the student on work-study who ran the photo lab so I got to see it all, from soup to prints. The film simulations in Silver Efex are impressive. I recognize the Ilford setups from the work of those folks who used to shoot Ilford film. The differences between Panatomic-X, Plus-X, and Tri-X are pretty much as I remember them. Back in the day we'd use the same film for most of our work, but would also use different emulsions for special assignments.
  4. kevistopheles
    Oct 21, 2014
    3,491
    4,836
    Original X100 so no Acros for me :(
  5. kevistopheles
    Oct 21, 2014
    3,491
    4,836
    I've been using Silver Efex and Tonality CC for years but I'd like to get better BW SOOC than I'm getting. I can do it with my Sony as well as my Fuji X10 (and X-P1 before that) so I figure I've gotta be able to do it with the X100 or at least get closer than I am now. Call it my little obsession. If I can't get there from here it's not the end of the world.
    FWIW I think Silver Efex is good but the latest release by DXO hasn't done much other than make it 64 bit. It's a step in the right direction but the UI and tools are getting long in the tooth. I prefer Tonality CC myself because it gives you much greater levels of control and IMHO the results are much better.
  6. Narsuitus
    2,084
    997
    Is Tonality available for the PC or only the Mac?
  7. lawsofphysics
    lawsofphysics Premium Member
    Apr 17, 2013
    2,647
    1,050
    I use LR CC and can get close to Silver Efex Pro. I find optimizing monochrome rendering with LR CC is very different than optimizing color rendering.
    I prefer Silver Efex Pro because the dodge and burn tools are virtual equivalents to what I did many in ancient times making prints from TR-X in the darkroom.
    I don't think you will ever achieve the B&W rendering you want without using a fast, easy solution. Diverse and flexible rendering tools exist for a reason.
  8. kevistopheles
    Oct 21, 2014
    3,491
    4,836
    Tonality is MacOS only but Skyluym's Luminar uses the same BW engine and it's available for MacOS and Windows. Skylum is likely sun setting Tonality soon anyway. I've been thinking of upgrading since they announced Luminar was getting a DAM and any license holders get a free upgrade. I've been using their tools for years and have always thought they were top notch.
    Narsuitus likes this.
  9. kevistopheles
    Oct 21, 2014
    3,491
    4,836
    I agree, tools like Tonality, Silver Efex, True Grain etc. will always give the best results. I have all of those tools (and then some) and I've processed many thousands of photos using them. What I'm trying to get at is how to get the best black and white straight out of camera. I don't mean BETTER than using dedicated black and white tools simply the best the camera is capable of. Case in point is my X10. My X- E1 and X-P1 were very very good (although not quite as good as the X10) and the X100 has flashes of it but mostly not. It's got wonderful color but the black and white, not so much. I've seen gorgeous black and white produced by the X100 so I'm sure I can improve what I'm getting.
    That said, it may not be possible to get where I want to go without resorting to using another tool and if that's so that's fine as well. I had an Olympus E-M10 for a while and I liked that camera quite a bit but I never did get decent SOOC black and white out of that thing. There was a lot to like about that camera (especially with the 14mm lens attached) but SOOC black and white wasn't one of them.
  10. kevistopheles
    Oct 21, 2014
    3,491
    4,836
    @Narsuitus I should mention that currently Tonality has a few more in terms of features for B&W (like micro-structure) than Luminar, but I've seen Skylum continue to add features to Luminar since it was released and almost no development has gone into Tonality other than minor upgrades so the hand writing is on the wall.
  11. DaveW19904
    DaveW19904 Premium Member
    Jun 10, 2014
    515
    154
    Dover, DE, USA, Earth
    I always liked the Lightroom BW#3, minus the grain and upping the exposure some. They recently added BW Punch and I like that pretty much SOOL (Straight out of lightroom :} )
    kevistopheles likes this.
  12. kevistopheles
    Oct 21, 2014
    3,491
    4,836
    I think the consensus so far is the best route to B&W is to use another tool.
    Speaking of other tools. Has anyone using the Mac OS tried Please login or register to view links? I ask because they have an add-in that is for specifically processing Fuji RAF files and it includes Acros and Classic Chrome simulations.
  13. mnhoj
    mnhoj Premium Member
    Aug 30, 2013
    828
    829
    los angeles
    Funny, I had forgotten that I had Picktorial and the X-Pack.
    Here are a few renderings from it and my X100F. Just the profile change.
    Picktorial's standard profile.
    Acros + R
    Velvia
    Kirstybell and kevistopheles like this.
  14. David Luttmann
    David Luttmann Premium Member
    Jul 30, 2013
    265
    112
    Canada
    For me, nothing has given results as good as Silver Efex. Used it for weddings and lifestyle shooting and landscape. For street work, I use a combo of Silver Efex and Analog Efex to get what I want. Out of camera....I have never really been satisfied.
  15. Arjay
    13,636
    5,447
    Silver Effex Pro (SEP) by DXO still has the same look & feel as the Google version - but it is much more stable. The Google version would frequently crash when using it with the lastest version of LR Classic. I certainly hope that DxO will add further functions to this package, but the gain in stability already is a valuable first step.
    One thing I haven't found in any other BW converter is SEP's color filter function (just two sliders for hue & strength) which color-biases BW conversion and fundamentally defines the contrast distribution in the converted image, especially if the original image contains many saturated or even complimentary colors. The amount of influence you can exert on a picture if you use this function as a first step in a conversion workflow is phenomenal.
    Anyway, I cannot imagine that any camera setting can offer as much influence on an image as SEP can.
  16. bonner01
    bonner01 Premium Member
    Aug 10, 2011
    823
    314
    Ventura, California
    Everyone has their own opinion of a good black and white image. One thing if for sure, one should always shoot with all the colors in your file for the most flexibility.(RAW/JPEG)
    I like to see the image in my viewfinder IN black and white so my solution is to shoot in "FINE + RAW" with one of the presets of black and white that is close to your taste. Of course, one must use only the EVF when shooting. Then one can edit either file depending your mood or, how the scene rendered in JPEG.
    Paul Levin likes this.
  17. Narsuitus
    2,084
    997
    I understand what you are saying and I agree.
    However, when I shoot black & white film in my rangefinder, seeing a color image in my viewfinder never seems to bother me. I wonder why.
