Vågen, Hidra, Norway
Discussion in 'Infrared (IR) Photography' started by Karl-Olav, Jul 24, 2017.
  1. Karl-Olav
    Karl-Olav Active Member
    Nov 28, 2015
    50
    27
    Hidra, Norway
    I have recently converted my X-Pro 1 to full spectrum. These pictures are shot with a 830 filter on a 18 mm f:2 lens handheld in RAW and developed in Lightroom. I am new to IR and converted to full spectrum to have all options available.
    zpuskas, leoda1945, DaveX and 6 others like this.
  2. nimbushopper
    nimbushopper Premium Member
    May 12, 2016
    300
    187
    Wow, these are beautiful!
  3. George B
    George B Member
    Apr 4, 2013
    Piedmont Region - North Carolina
    Those are wonderful images and I appreciate you posting these. The timing is perfect for me. I spent a good part of last night trying to decide which filter to choose before sending my X-Pro1 off this week for conversion. I am torn between 850nm and full spectrum. I know I will process the majority of my IR shots as black and white, but having the options that full spectrum provides is keeping me on the fence. Not sure if I want to deal with lens filters that full spectrum requires or not. I have an X-Pro2 for "normal" color shots and is easy enough to carry two bodies. Decisions, Decisions :)
  4. Karl-Olav
    Nov 28, 2015
    50
    27
    Hidra, Norway
    If I had to do it over, I would go for 830 or 850 conversion. It is expensive to purchase external filters for each size lense. But I now also have the option to produce false color IR with a 720 filter and use the X-Pro 1 as a normal camera with a IR blocking filter. Since I have X-T2 as the normal camera a 850 conversion on the X-Pro 1 is really all I needed.
  5. George B
    George B Member
    Apr 4, 2013
    Thanks for that advice, good points. I use a lot of adapted lenses of various filter sizes so unless I got large filters and step down rings, the costs would add up quickly.
  6. Jackson
    Jackson Active Member
    Feb 7, 2016
    83
    33
    It turns out the XT-2 is incredibly sensitive to IR light without conversion. I've been shooting with a Hoya 720nm filter and am able to shoot handheld at ~3200 ISO at f4/f5 and around 1/25 with optical stabilization. Not too bad. It's kind of a known secret of the X-T2. Might give it a shot. I had an XM1 converted to full spectrum recently and still waiting for it to be returned to me. Great images by the way!
    dseevv and Karl-Olav like this.
  7. Karl-Olav
    Nov 28, 2015
    50
    27
    Hidra, Norway
    I have to give it a try with my X-T2. Thanks for the tip.
  8. Max Fstop
    Max Fstop Well-Known Member
    Jul 7, 2017
    101
    51
    Norfolk, UK
    Excellent set ;)
