X-E2 commander mode flash output
Discussion in 'X-E1, X-E2, X-E2S and X-E3' started by i-Click, Mar 14, 2018.
  1. i-Click
    i-Click New Member
    Mar 13, 2018
    Hi all,
    I’m new here. I just bought an X-E2 and am having fun learning to use it. I was playing around with the popup flash in commander mode but it wants to fire at full power affecting the exposure. Is there a way to set it so it doesn’t add light to the exposure?
    Thanks in advance.
  2. le boecere
    le boecere New Member
    Oct 15, 2017
    Go to the Shooting Menu #4 - Flash Setup -Flash Compensation
    (the X-E2 is a wonderful camera)
  3. vague_logic
    vague_logic Premium Member
    Sep 17, 2014
    413
    159
    I'm not sure if you have understood what the "Commander" mode is. It merely surpasses the pre-flash so it can optically trigger remote flashes with optical sensors. With the normal pre-flash they would not synchronise. Therefore, all you can do is adjust the flash compensation to reduce the amount of light the flash emits though, you can't stop it flashing or it would fail to fire remote flash units.
  4. i-Click
    i-Click New Member
    Mar 13, 2018
    Thank you for your reply. I do understand the idea of the commander mode. I'm used to the way my old Nikon D7000 allowed me to use commander mode to trigger the external flash but to remain off for the exposure. I couldn't find this option for the X-E2.
  5. jknights
    13,672
    3,207
    The Nikon Commander mode uses IR to 'talk' to other off camera flashes. This feature is not present in Fuji cameras.
  6. i-Click
    i-Click New Member
    Mar 13, 2018
    Gotcha. Thank you.
