X-H1 Annoying feature!
Discussion in 'X-H1' started by Mike Gorman, Mar 14, 2018.
  1. Mike Gorman
    Mike Gorman Premium Member
    Mar 4, 2017
    1,378
    885
    West London
    An annoying feature of the new wonder machine is “Power Saving Mode” in that when using the LCD or EVF in normal mode after about 10-15 seconds of viewing but otherwise inactivity, the EVF and LCD go into power saving mode and the refresh rate is halved and the view becomes a bit jittery and jerky as the screens then struggle to keep the smoothness of the usual operation! Press a the shutter halfway or the back focus button and the smooth operation returns for a short while
    Apparently this is a feature not a fault as Fuji UK support informed me! also this feature happens on the X-T2 as well, this phenomenon doesn’t happen in boost mode. Fuji UK promised to pass on my comments to Japan. I never noticed this on my X-T2!
    Hopefully a firmware update will give the opportunity to switch this feature off.
  2. pszilard
    pszilard RemektekMedia.com
    Sep 14, 2011
    2,763
    933
    Sydney, Australia
    If you put it in High Performance mode this does not happen. Not sure if you can do this without the battery grip, but there is a switch on the grip for doing this.
  3. Lars Steenhoff
    Lars Steenhoff New Member
    Mar 14, 2018
    High Performance mode ( Boost mode ) can be enabled without the grip, both on xt2 and xh1
    Mike Gorman likes this.
  4. Mike Gorman
    Mar 4, 2017
    1,378
    885
    West London
    Lars, is quite correct, I hope Fujifilm is listening!
  5. visorvet
    1,978
    603
    If you can prevent this by simply switching into High Performance/Boost mode (in-camera, no battery grip), what is it you’d like Fuji to hear and do? Something has to give if you want to prioritize power-saving.
    Sounds like it is no different from the X-T2 in this regard.
  6. Mike Gorman
    Mar 4, 2017
    1,378
    885
    West London
    I personally like to turn off power-saving or at least extend the non P-S period to say a minute, because power consumption is greater in boost mode than in normal mode, 13 seconds is not enough!
    visorvet likes this.
  7. Malsam
    Malsam Member
    Aug 4, 2015
    50
    singapore
    I find this dizzy initially and thought my unit might be spoil until I saw this post. Yes it’s annoying but a press of the shutter will resolved it is fine...only if the “recovery” is faster...
  8. Greg_E
    Greg_E Premium Member
    Jul 7, 2012
    2,419
    299
    Seems like it would be better to have a user set timer, maybe something like 2 minutes? Or maybe just off? Going into HP mode eats even more battery than normal active mode.
  9. Mike Gorman
    Mar 4, 2017
    1,378
    885
    West London
    My point exactly, if I can select an Auto Power off time of 15 sec to 5 minutes or off in the sensible range offered, why can’t I do the same for LCD & VF refresh rate slow down? Hopefully Fuji will take note and give us a firmware fix!
  10. Rblum22
    Rblum22 Member
    Mar 25, 2016
    87
    21
    Drums, PA
    Does anyone's viewfinder seem to be be insanely bright when it is first turned on (for a second or 2) before it begins to show the actual exposure of the scene? This seems to happen when I turn the camera on and after the viewfinder engages when I am done reviewing photos on the LCD.
  11. icSlowMo
    icSlowMo Member
    Mar 7, 2017
    19
    Mine does the same, but if you tap the shutter button, seems to correct it faster...
    Chris
