X-T2 Focusing errors during wedding
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by djbe, Jun 19, 2017.
  1. MontyBigglesworth
    MontyBigglesworth Premium Member
    Jun 23, 2015
    231
    58
    Cheltenham, UK
    I noticed you are shooting in LED lighting? I can see that may be a problem. If the LEDs are cycling through RGB to make white that would screw up the white balance and/or exposure. Also some cheap LED lighting has very little smoothing which causes the LEDs flicker a lot.
    I have found some cheap LED lighting gives me a headache because the flickering is so bad - god knows what that would do to a camera trying to focus!
  2. djbe
    djbe New Member
    Jan 12, 2017
    I thought it was na Af-c issue too but I was set to Af-s and I never use face detect or eye detect
    That would be an issue if I had to lock focus every single shot since the buttons are tiny and that's just not practical. I'm trying to figure out if it's my camera or everyone's that does this.
    I shoot exclusively with the grip I don't think I can hold the camera for a long time without it.
  3. Jonimages
    Jonimages Premium Member
    Nov 19, 2014
    703
    419
    Silverhill-AL
    You have to give us more info. The lens used makes a huge difference. My 56 1.2 hunts, even in good light. My 100-400 will lock better in low light, same as 35 f2, 18-55. Have you tested since the wedding?
  4. Photoron
    Photoron Premium Member
    Mar 8, 2013
    161
    27
    Long Island, NY
    The term " lock focus" is used a lot, & I am not sure the meaning is universally understood. If I am in bbf, continuous focus, & I achieve focus & then release the bbf button, doesn't the camera stop focusing, & remain focused at that last point, & if so, is focus "locked?"
  5. rixpix
    rixpix Member
    Jul 26, 2014
    51
    Not sure what you mean by "full" above, but if BBF is set up on an X-T2 as has been described elsewhere, then simply lifting your finger off the button you've assigned to BBF locks the focus until you press it again (of course you have to decouple AF from the shutter button - an essential part of setting up BBF).
  6. rixpix
    rixpix Member
    Jul 26, 2014
    51
    I take "lock focus" to mean "won't change subsequently by automatic means", as opposed to "lock on" which some people might use to refer to the process of the AF system achieving focus automatically (and possibly then tracking a moving subject).
    To answer your question, YES. Of course, as I have mentioned in my previous post, this assumes you have decoupled AF from the shutter button - an essential part of BFF setup.
  7. Photoron
    Mar 8, 2013
    161
    27
    Long Island, NY
    Yes, as I have found, but when people mention having to use the AF-l button to "lock" focus, even when in bbf, the terms become unclear.
  8. jecottrell
    jecottrell Member
    Aug 26, 2014
    96
    Tucson, AZ, United States
    If you made the switch to Fuji without trying it first, and have sold your Nikon kit, yes you have made a mistake. Fuji is NOT a DSLR. Some people make it work and are happy with it, many can't and are not.
    The autofocus may be fast (as compared to systems that are slower) and I've found it less accurate than my DSLR in low light.
    pharyngealized and Photoron like this.
  9. Solo with others
    Solo with others Premium Member
    Nov 28, 2014
    146
    141
    Dallas, TX
    I don't feel I am getting enough information from the OP to help them (even though it has been asked for). I'm starting to think they are looking for validation more than help. Nothing more than my opinion.
  10. trainer
    trainer Premium Member
    Jun 29, 2014
    2,630
    3,205
    upstate NY, United States
    What size focusing point were you using? I believe under low light the camera uses contrast detect autofocusing. You do have to find an area with contrast to place the focus point on. Also the focus points are not cross type. More setting info on the shoot would be helpful.
  11. X-Carey
    X-Carey Member
    Jun 2, 2017
    29
    I suggest you guys read this thread: Please login or register to view links
    and comment on whether you see the same thing with the X-T2. Thanks.
  12. djbe
    djbe New Member
    Jan 12, 2017
    UPDATE:
    Reset everything installed newest firmware and everything works fine.
    I am shooting back button focus and I can't seem to recreate the problem in the same lighting situation. I tried af-c and af-s and it's all working fine now.
    To all the guys that genuinely believed me thanks to those that didn't thanks too ;)
    New problem why did Fuji make the frame no full error a thing?!
  13. X-Carey
    X-Carey Member
    Jun 2, 2017
    29
    So with the latest firmware, do you experience the changing focus with half-press as explained in the above link? Inquiring minds want to know. Thanks! I'm hoping X-T20 will get an upgrade to fix it.
    And what the heck is a "frame no full" error?
  14. djbe
    djbe New Member
    Jan 12, 2017
    Nope no problem anymore. Frame Number Full error is when your camera is set to renew instead of continuous. When you shoot to 9999 every image you try and shoot will come up with the frame no full because for some stupid reason it won't reset itself.
    Solution change cards, format take a shot then change to continuous.
