X100F: Front Click Wheel
Discussion in 'X100F, X100T, X100S, X100, and X70' started by (c)ow, Jul 25, 2017.
  1. (c)ow
    (c)ow Premium Member
    Apr 19, 2013
    1,223
    661
    Stuttgart, Germany
    What function did you folks assign to the front click wheel. Coming from X100S I can't decide what to use. Of course it depends on shooting style etc.. Just curious...
  2. Cher
    Cher Premium Member
    Dec 7, 2013
    456
    247
    Denver, CO
    I keep the exposure comp dial on C, use the front wheel for exposure compensation. I also have my X-T2 set up like this and wanted the 2 cameras set up as similar as possible. This set up has been working well for me.
  3. bralk
    bralk Active Member
    Nov 30, 2016
    34
    26
    Denmark
    Moin Oliver
    I have set the click button (the one at the ovf/lcd lever) to lock exposure. I activate it with my middle finger and hit the exposure button with my index finger. Great for repeating shots with locked focus. (in AF-S mode)
    I have just exchanged my old original x100 for the new F model and so far I am very pleased with it. My setup for now is RAW+Fine Acros. DR 200. RAW conversion in x-transformer which recognizes the DR 200 setting.
    The resulting DNG file goes to Photoshop CS6.
    Still experimenting/learning the camera
    cheers/MfG
  4. (c)ow
    Apr 19, 2013
    1,223
    661
    Stuttgart, Germany
    Actually this is a pretty good idea! The front click wheel is much easier to change than the exposure comp. dial. Will try that.
    Cher likes this.
  5. (c)ow
    Apr 19, 2013
    1,223
    661
    Stuttgart, Germany
    I ment the little click wheel, not the button inside the lever. Just below the on/off switch
    I came from the X100S and like the IQ and resolution of the F a lot. I use LR (+ IXT in cases where fine details are wanted).
  6. Robmas4229
    Robmas4229 Premium Member
    Mar 13, 2015
    690
    292
    Florida, USA
    As far as I've been able to find, the front command dial can only be used for exposure compensation (when Exp.Comp. dial is set to C), and/or ISO (if ISO Dial Setting is set to "Command" in the MENU/SETUP/BUTTON DIAL SETTINGS/ISO DIAL SETTING/COMMAND). If you have the Exp Comp dial set to C, then pressing the front command dial toggles between the two controls.
    Hope I said this correctly, . . .
  7. Robmas4229
    Mar 13, 2015
    690
    292
    Florida, USA
    I tried this but found it too easy to accidentally change the exposure compensation.
  8. ChiDN
    ChiDN Fujiholic Cub Fan
    Aug 2, 2013
    1,066
    476
    Chicago, IL
    I've been using it that way as well. Not that sure of it though, liked it at first but...we'll see.
  9. rfh1652
    rfh1652 Premium Member
    Mar 6, 2013
    284
    61
    Rocky Mountains USA
    If you go into the button/dial settings in the setup menu you can change the iso dial A setting from auto to command. This will allow you the adjust exposure and then in you press the dial you can adjust iso.
  10. Cher
    Cher Premium Member
    Dec 7, 2013
    456
    247
    Denver, CO
    That's exactly why I like it, easy peasy to adjust while shooting :)
    Robmas4229 likes this.
  11. (c)ow
    Apr 19, 2013
    1,223
    661
    Stuttgart, Germany
    I set Exp. Comp. to "C" and use the click wheel for exposure comp. The on/off function prevents from accidentally changing. Shot a concert last night and had to use exp. comp. a lot for to get moody images.
