XP2: Backbutton Focus
Discussion in 'X-Pro2 and X-Pro1' started by (c)ow, Aug 11, 2017.
  1. (c)ow
    (c)ow Premium Member
    Apr 19, 2013
    1,226
    661
    Stuttgart, Germany
    On a shoot last night I tried the backbutton focus, which I haven't used for a long time because back then you needed to half-push the trigger and then lock focus with the AF-L button. Too cumbersome! Wow, when did they change that? Now the AF-L button can focus!
    One more thing I'd like to have: the option to auto unlock the focus after taking the image. Or re-focus when pushing the AF-L button again. To make clear: I still want the lock function, not hold the AF-L button. Does anyone know?
  2. (c)ow
    Apr 19, 2013
    1,226
    661
    Stuttgart, Germany
    Ahh...I just found a post that states when switchin-off focus function from the shutter, bbf works like half-pressing the shutter (to set focus). Mmmhh...that means I need to decide bbf OR shutter focus, no AND/OR...
  3. YogiMik
    YogiMik Premium Member
    Sep 27, 2014
    2,239
    1,508
    Norway
    That is one of the deal breakers for me to buy X-T2. The way it was before is more useful and practical.
  4. fatdeko
    fatdeko Premium Member
    Jan 6, 2014
    530
    239
    Portland, Maine
    There is the Manual Focus work around....
    When set to Manual focus, the AF-L button becomes a focus assistant: you press it and it focuses on your focal point (from which, presumably, you are supposed to fine tune your focus manually for depth of field positioning etc.)
    So with AF-S and AF-C, you can have regular half-press shutter AF, and then by switching to M, you have both Manual focus and true BBF.
    (c)ow and bcirwin like this.
  5. (c)ow
    Apr 19, 2013
    1,226
    661
    Stuttgart, Germany
    Manual focus could be a way! I tried that but I need to find out how to disable the focus peek. I mean the magnification. That's somehow disturbing. Is there an easy way to get back to original view when using the EVF?
  6. Jarbi
    Jarbi Active Member
    Nov 27, 2013
    41
    43
    United Kingdom
    Hi,
    I use manual and bbf all the time as it is quicker and more convenient. You an disable focus peaking with the EVF by setting it to "standard" when it is not critical.
    (c)ow likes this.
  7. (c)ow
    Apr 19, 2013
    1,226
    661
    Stuttgart, Germany
    I tried this last night: MF and BBF via AF-L button. Works fine, when I find the AF-L button...
    bcirwin likes this.
  8. Ken Ford
    Ken Ford Well-Known Member
    Mar 7, 2011
    224
    61
    Suburban Chicago, IL USA
    What I did was move AF-L to the AE-L button - it's a little easier to find. If it could be moved to a press of the joystick in MF model only it would be almost ideal.
    bcirwin likes this.
  9. Jarbi
    Jarbi Active Member
    Nov 27, 2013
    41
    43
    United Kingdom
    I put a tiny blob of Sugru on the AF-L button and now I always find it.
  10. (c)ow
    Apr 19, 2013
    1,226
    661
    Stuttgart, Germany
    I tried Sugru, didn't stick...
  11. Oldtimer
    Oldtimer Well-Known Member
    Jul 30, 2017
    134
    50
    I'm not familiar with the pro, does it have a front function button?
    On my X-T2 I can assign af=on to the front facing button. So I have front-button "back-button" focussing!
  12. Ken Ford
    Mar 7, 2011
    224
    61
    I was thinking about making a little dot out of two part epoxy and attaching it with something removable.
  13. (c)ow
    Apr 19, 2013
    1,226
    661
    Stuttgart, Germany
    Arjay gave this tip: he uses stickers that are meant to stick on the back of cabinet doors (where the door touches a board) to not crate a sound when the door gets closed. I bought a sheet with - I don't know, maybe 20 pcs. - of these self-adhesive (silicon?) stickers and cut them to size with an office hole puncher, which was also a tip from Arjay. They don't cost a fortune and when I loose one, I put the next on.
    I'm a big fan of Sugru but it didn't stay on. I guess the surface of the button is too smooth.
  14. Ken Ford
    Mar 7, 2011
    224
    61
    That was my first idea, but I haven't found any small and thin enough. I have a multi hole leather punch, but material thickness has been an issue. I'll keep looking.
  15. (c)ow
    Apr 19, 2013
    1,226
    661
    Stuttgart, Germany
    I personally don't like this company but check it out: Please login to view links
    With a proper search string (that I struggle with in English) you'll find something on the web, I'm sure.
  16. Hughe
    Hughe New Member
    Sep 19, 2015
    Neosho, MO
    I put a small pics of sticky back VELCRO on the button
  17. Ken Ford
    Mar 7, 2011
    224
    61
    That's a good idea!
  18. Oldtimer
    Jul 30, 2017
    134
    50
    I'd be tempted to put actual small pieces on rather than just pics. You will get better adhesion. :)
